Now THAT is a warranty!Mick Strider said:Our warrantee is simple.
If you are dissatisfied, we will do what we can to make it right. If you break a knife, well replace it. If we WONT replace it, (because youre an idiot) we WILL give you back your money. Period!
Because you specifically stated that if I did ask for a replacement the knife would be marked as abused and the warrenty voided. I don't need to test it when the maker clearly states it and the description is inferior.How can you say our warrantee isn't as good as another, if you have never used it?
Ask them and find out, lots do....why should knife companies give you product to do it?
It costs me about $1000 or so per year to do it (not including the cost of the knives I buy), mostly in duty and returns to makers, plus pass around to other members.Are you being asked or paid to do it?
If it breaks before you said it would yes. It isn't a hard concept to grasp, the knife should be able to do what it is promoted to do.So then should we send a new knife to ANYONE who decides to put it in a vise and break it?
Was this with the NIB edge, or was it sharpened? Any difference in edge geometry could also be rectified in minutes on a x-coarse stone. Lots of knives come with low NIB sharpness, even the better brands occasionally release one under par.k_randomfactor said:1) Cuttingtest - pulling:
Testmedium here was the by now known Polyporpylenrope with an 8mm (0.315") diameter. Tested was, how well the knive will cut through that rope with a pulling cut and normal pressure applied. Several trials were done one after another, the number of cuts needed to finally cut through the rope were noted. At the end of that test an average was calculated. These were compared and points given in analogy to the cutting performance.
2) Cuttingtest - pushing down:
Testmedium was again the 8mm (0.315") Polypropylenrope. Tested was, how good the knive would cut through the rope only by pushing down, no longitudinal movement. Here the blade was pressed down hard with both hands. It wsa measured, how deep the blade could penetrate the rope or how often a rocking/swaying (?) motion ws needed to cut through the rope. At the end of this test, again an average was calculated. These were compared and points given in analogy to the cutting perfomance.
3) Test - edge retention:
To test the staiblity of the edge and the wear while using it, a very nasty material was cut : a steel square tub (St-37). The edge was pulled over the edge of that square tub several times with light pressure. Inbetween these cuts the edge was tested on the rope to compare how good or bad it could cut that one. Thereby it became clear, that the original edge and sharpness was lost very fast, still both knives could still cut even after several cuts on the square tub. In comparison the Strider SPB-S30V blade proved to keep its edge slightly better.
That ER handle looked as funky as all get out to me, that isn't surprising. The strider grips have high security even when lubricated, both coard wrapped and G10.4) Grip - test:
The Knive's blade was mounted to a vice, the handle and hand were rubbed with the good and old-known Ballistol-weapon oil. This was done to simulate the effect of Dirt, blod and humidity. Here the secure grip and/or how easily it would slip out of the user's hand was tested. The subjective results were converted into points. Here the Strider proved to have a lot of grip in oily condition (not less than dry), while the Extrema Ratio was very slippery due to the smooht/slick surface.
Liner / integrals are quite strong under compression and vertical loads, however they are instable under side torques which can cause the bar to move across the lock. If this happens it can either disengage completely, or engage only partially and then a shear failure is trivial to achieve. You would want to examine this as it is the real problems with that type of lock, the raw strength is rarely a problem.5) Test blade tip:
To test the stability of the blade tip and also the whole knive construction while stabbing, both knives were pushed straight through a 2mm (0.079") thick steel plate (St-37 construction steel). Here a hydraulic press was used. the Strider GB bend noticably to the side, but flexed back into its inital position. At a hydraulic pressure of 85bar the tip broke off - exactly at the point of time where it completely penetrated the steel plate. The Extrema Ratio blade was "not impressed" (?), the locking bent at a pressure of 65bar though. The bolt safeguard of the locking (??) was not activated on purpose, to prevent the handle from blowing/breaking appart. With that safety a higher pressure would have been possible and the Fulcrum might have also penetrated the steel plate.
6) Lock(-ing) test
Both knives were first tested with spine-whacking, to perform a dynamic test to the lock. Here the back of both blades were repeatedly beaten onto a hard surfaceö Both knives passed the test without difficulties. Then a static test to the lock was performed with a hydraulic press. With a slowly raising pressure across the blade pivot, the maximum load was tested. The Fulcrums bolt/hammer of it's lock failed at a pressure of 70bar, releasing it's blade (without bolt safety/safeguard). With activated bolt safety a higher load would havebeen possible, until the whole handle would break apart. the liner locking mechanism of the Strider GM kept up until 80bar, untl the liner failed. The extreme load/force/stress (?) did not leave any marks on both knives.
Here you would want to be a little closer to normal application, it is impossible to put pressure in the middle of a blade. Lock the tip and deflect the knife sideways to see if the blade breaks before the lock is damaged.7)bending test blade:
Both blades were one after another put onto two pads/bases and put under presssure with the hydraulic press in the middle. The Strider GB blade proved to be of etreme elasticity - in spite of the powdermetallic steel (?). Not before a pressure of 83 bar (which resembles a high load in transverse direction), the blade broke into several parts. At that point of testing a bending degree of nearly 30° was reached. The extreme thick blade of the Extreme Ratio Fulcrum II passed that test nearly unimpressed. It kept up until the hydraulics maximum pressure of 85 bar was reached and moved back nearly to it's initial position. A slightly deviation of one to two degree (angular transformation) (?) was left.
8)bearing test:
To test the bearing and handle construction, both knives were put under vertical load/pressure with the hydraulic press.The knives were positioned in such way, that the handle was on the right, the blade on the left side based onto a block, putting pressure directly onto the bearing. The hydraulic press support point was immediatly behind the pivot. The Strider GB proved its impressive flexibility of its handle, which flexed back into its original state. Here the Ti-liners showed their strenght and flexibility. At a pressure of 80bar the outer ring of the pivot blew off. The Extrema Ratio Fulcrum also withstood 80bar, a permanent deformation of the handles stayed.
Straighten it back out and then insert it back into the sheath. Can people really not see this solution?Mick Strider said:A bent knife is totally useless, I would rather have a broken useful part of a knife than a bent piece of metal that wont even go back into its sheath ..
I publish several papers each year in peer reviewed journals, several coming out right now, and being presenting at conferences.Mick Strider said:Are you a scientist? NO
Cliff Stamp said:I publish several papers each year in peer reviewed journals, several coming out right now, and being presenting at conferences.
I am currently doing research in solid state physics at Memorial University of Newfoundland while teaching first year university physics courses
Obviously any part that's in English and follows a logical train of thought.BlackShark said:To all Cliff Stamps out there:
Hmmm... Which part of 'if you break it, we'll replace it' don't you understand? ...
Mick Strider said:if you like, I can show you a video of me lifting my dodge truck over my head ..do you always believe what you see in videos?
If you base your knife choice by a video ..you dont need a Strider Knife buy more videos instead.
m
Jerry Busse said:If youd like, Ill stand side by side with you in a Live comparative demonstration with one of our relatively inexpensive Swamp Rat blades, and vastly outperform ANY Strider CPM S30V blade in cutting, impact strength, lateral toughness, etc. . .
Jerry Busse
Busse Combat Knife Co.
