I’m most puzzled at bevel angles. Decades of super steels and I haven’t seen a folder with an aggressive bevel angle... ever. I know why a manufacturer would err on the side of thick but come on, plain edge knives with more acute angles start cuts so much better.
This is because a tradition has developed of testing steels by doing non-knife like tasks (materials harder than wood). The most prominent example of this is INFI (which is better than many CPMs at true knife-like tasks, again nothing harder than maple wood): This is what happens to INFI when it is ground to a convex 32-34 degrees inclusive final, and you lightly chop some maple (below is a comparable -slightly thinner- edge in 5160):
Like many newer steels, they do not tolerate reasonably thin angles (15 dps or less), so that is why they are ground thicker, as the tests that developed them seem to favour edge holding at blunt angles (but often non-impact tasks, though INFI did well at not rolling, even if it warped easily): So gradual abrasion tests and that kind of thing.
This below is how many CPMs typically behave under chopping impact (CPM 3V here being the best, taking 20 plus hits for the apex "lip" seen here). S30V, the worst I have seen, will do this merely slicing 1/8" cardboard (Gerber 70th Mark II), or in single chops in maple(!).
Note how the cheap low-end Chinese 420J is completely indifferent to wood impact, the one short lip area being the result of an accidental twisting motion. Angles were similarly thick: Near 20 dps.
On the other hand, using the same 420J and hitting metal will yield severe edge damage as the apex compresses, while other higher-end steels will fare better... The only problem is that this superior high end steel performance appears while doing completely knife-irrelevant tasks, like cutting into metal, or maybe high abrasion tasks...
So yes, strangely enough, something that holds up better against harder (or in knife-unrelated industrial tests) will do worse, relatively, on more realistically soft mediums, at thinner edge angles, especially if chopping (the apex "lip" appearing easily under nail rubbing). The only way to disguise this is to stay safer on the side of thicker edges: Hence the non-aggressive above 15 dps (30 inclusive) edges, usually an amazing 20-25 dps, that you observed.
Gaston
