- Jun 21, 2002
I like Blackjack knives, Chris Reeve, Becker, Tops.....All of them have good points to me.DazedandConfzed said:And what knife would you prefer?
So are Ranger Knives, and they are by the one guy, and significantly cheaper than TOPS. This of course should not make them cost more, lots of very high end custom makers use CNC machines, jigs and so on, they are not overpriced because they do so.TorzJohnson said:A couple of years ago I read a post by Trace Rinaldi where he said TOPS knives were mostly hand made. .
NGK-Webmaster said:I like Blackjack knives, Chris Reeve, Becker, Tops.....All of them have good points to me.
DazedandConfzed said:Isn't Becker knives just a higher end of Camillus knives?
DazedandConfzed said:I think they are and it seems as if Camillus is not known for the best of craftsmanship, course a knife is a knife to me.
Quiet Storm said:Becker is their outdoor knife line. If anything, they're Camillus' slightly lower end knives.
Where did you get this from?
This isn't where the cost comes from. The influence of materials and design is significant, but for many pieces, the majority of the price markup is simply created by demand, or to place the piece in a particular niche where it will create the most profit. As noted you can find single custom makers who are significantly cheaper than TOPS, working with a more complicated heat treat in a steel which is more difficult to machine, so you can't argue cost from materials or manufacturing.DazedandConfzed said:...from looking at the basic designs of a knife they don't seem like anything extraordinary to make by hand
Cliff Stamp said:This isn't where the cost comes from. The influence of materials and design is significant, but for many pieces, the majority of the price markup is simply created by demand, or to place the piece in a particular niche where it will create the most profit. As noted you can find single custom makers who are significantly cheaper than TOPS, working with a more complicated heat treat in a steel which is more difficult to machine, so you can't argue cost from materials or manufacturing.
-Cliff
Cliff Stamp said:working with a more complicated heat treat in a steel which is more difficult to machine, so you can't argue cost from materials or manufacturing.
-Cliff
I would assume it is similar to :Brian Jones said:...TOPS heat-treat process?
It is decent but overkill in the carbon percentage, you don't need all of that for a heavy chopper, it is really nice in small blades ran full hard though.Thomas Linton said:This may make it a good choice for "chopper" knives.
The accepted defination now is that one guy made it. This is a loose defination though as it can be heat treated by someone else, and its still considered custom.I would not consider a knife custom unless it was made how I wanted it. However it is made is irrelevant. In none of these cases does custom imply quality superior to high end production.averageguy said:Knives need to be profiled and ground by hand for me to consider them custom.
Cliff Stamp said:I would assume it is similar to :
-Cliff
