Cliff Stamp
BANNED
- Oct 5, 1998
The above procedure is standard practice for 1095, a well known carbon steel. As noted, more complicated procedures are necessary for higher alloy steels to deal with the lower transformation temperatures, secondary carbide formers, and higher sensitivety to soak times all well known consequences of working with more complicated steels.Brian Jones said:You drew a conclusion on nothing but an assumption.
Yes there are steels which are more complicated to heat treat than 1095, this should not be a revelation. You even need different equipment to reach the soak temps on some of the really high alloy steels. If you went to the same temps with 1095 you would simply blow the steel. Then there is the lack of a differential heat treat which alone makes the process more complicated in those that have them.
None of this by the way makes it a bad steel, one of the goals of designing S30V for example was to make it easier to heat treat than S90V.
That is how I view it, but the industry doesn't. The word custom has a really odd defination which is hard to exactly state especially when you have makers using assistants, or farming out several parts of the production like blanking, heat treating, coating, sharpening.allenC said:If you make 1000 knives that are to the exact same specifications, then they are not custom-make, even if they are hand crafted.
-Cliff
