- Mar 28, 2020
You should try it. It is great for making fine kindling.
I can make fine kindling with a hatchet much faster. If I was using a fire starter and needed some fluff then I would slice some wooden fluff with my knife.
Cost, has to be worked cool so it doesn't air harden and then abrasion for all of the steps is slower and in the end, the sword isn't really that much better of a sword (would be my guess).
But the flip side of it is if nobody does it, sooner or later there will be a small group of people who will pay a mint for it.
Friend if mine had a bunch of chisels made out of 3V - really just bar stock stuck in a handle. I devised a novel sharpening method for chisels that helps chisels a bit soft hold a fine edge. After years of talking about how good the chisels were and how tough they were, he sent me a message and said my sharpening method saved his chisels because at 59 hardness, they were too soft.
Sometimes I wonder why stories change so fast like that, but the point of it was that while it may be very tough, and it may have been very abrasion resistant compared to plain steels, it doesn't make a better chisel for use (japanese white II and I are probably about as good as it gets for chisels - 3V can't take the ideal hardness that they can attain and it makes a sweeter-working chisel. Even a shaped and reheated vintage file makes a better chisel, but none of those are likely to be tougher than 3V - the toughness just isn't needed, and neither is wear resistance).
I think most people would agree about the toughness not being needed when it comes to most types of knives and cutting tools we all use everyday, escpecially when it comes to fine edged slicing food prep knives and wood working chisel type blades. There's only really a few type of blades where super high toughness is needed, like competition choppers, machetes maybe as well. That's why I took the discussion over to the sword end of things where more impact abuse is expected to be normal use, where as most people consider hard use kind of abusive for slicing tools.
I think white paper steels are known for taking a very fine thin edge at very high HRC, and is a very pure steel. More toothy wear resistant steels are good for EDC knives where you are just cutting through cardboard and other stuff that can eat up blaade edges. I have noticed chefs and wood workers like a very fine edge, highly polished and not toothy, also soemthing they can touch up reasonably fast. Even when it comes to general EDC folders I tend to carry 2 types with me at all times, 1 CPM steel with Vanadium etc with good wear, and another Sandvik steel like a 12C27 which I put a very fine edge on for slicing and that is easy to re sharpen. I don't really walk around with 3 types of stones on me daily, so if I chip or ding my CPM wear steel, it's going to be a pain in the butt to reprofile outside, but I can reprofile and touch up my Sandvik 12C27 and get it back to razor sharp and remove rolls or chips on the go easily with just a little pocket stone. I like all types of steel, I do enjoy the high wear Bohler and CPM newer steels, but I still find a need for the more simple steels with refined grain structure that take fast fine edges. I've been enjoying my K390 Delica for the past few weeks, it's amazing stuff, but I don't enjoy the thought of repairing a chip on stones. It takes
a killer edge and I just hone it on ceramic sticks and strop it back to razor sharp, the edge stability and HRC is insane on it, just not really the type of knife I want to reprofile outside.
ditto - set the hatchet edge into the kindling quickly, then lift all of it and one tap for each piece of it. No froe or mallet or any of that, though the hatchet can be laid upside down and the kindling malleted into the edge. If there were small dry sticks (there usually are), even hanging dead on trees within reach, I'd skip the kindling, anyway.I can make fine kindling with a hatchet much faster. If I was using a fire starter and needed some fluff then I would slice some wooden fluff with my knife.
by the way, this isn't an association fallacy - they use 1095 for just about everything. Nobody said anything about toughness. there's a huge fascination with toughness in most knife circles, but I think it's a cliquey sales point. I don't know where 1095's toughness would be challenged in butchering. This isn't forged in fire or some fake scenario - the knife cuts skin and meat. A saw cuts bone.
What's even a little more strange is that forum members who spend their days reading charts and sharpening knives used in contrived scenarios shoot barbs at groups who are actually using the knives heavily and not for a made-up purpose or a contest.
They tend to work pretty fast, actually (the amish) despite backwards stories. They generally have a good disposition and can go into heavy work mode without issue. As to why they generally like 1095 vs. anything else for butchering, they probably like that it grinds easily and is very even. I don't think anyone makes a good thin butcher knife in AEB-L for anything close to the price of the ontario 1095 knives.
For woodworking, I found simpler steels are generally better for me (I do a lot of woodworking from rough to finish just with hand tools). I even did a durability test and found M4 and XHP to be the longest wearing of the steels that I used (high carbide count and good high hardness without being fragile lead to wins in those tests. I used 3V in one with a bos heat treated plane blade, but the spec ordered was 61 on the c scale and it came back 59 - I guess they're just so used to that). XHP was at about 63 and M4 was 64.
In a standardized test, all of those blew away oil hardened steels. When it gets to actually doing woodwork, the plainer steels (O1 and older cast steel) are much tougher at the fine edge for some reason. If the damage gets larger, maybe the story changes (I can trim brass and wood junctions with a high speed steel chisel, but the same chisel lets go of its fine edge earlier - we generally work with angles around 30 degrees, so the higher vanadium steels with large carbides are out -they leave little lines all over work).
At any rate, after doing the standardized test, I found keeping all of the little nicks out of XHP a pain because removing a couple of thousandths of steel all the time is a pain. The plainer steels seemed to be tougher (XHP isn't that tough, but again, the cast steel irons seem to do the best for reasons I couldn't guess - they're not soft by any means to gain toughness). The M4 and 3v irons went back to their respective owners. The desire of 3V to really hold on to a burr when you are going to sharpen 6 or 8 times in a given shop session is a huge pain. M4 sharpened nicely (these are all PMs, not the pre-PM versions), but had more friction in the cut than the other irons and probably cost a moon - a dedicated woodworker may have four bench planes, but a whole bunch of others - perhaps with a hundred irons - M4 isn't practical for that).
When it comes down to it, after all of that, I found ease of sharpening more important as long as an iron wasn't absolute trash - to keep ahead of small nicks and bits, and 3V or anything else takes about twice as long to sharpen, even with diamonds (which you don't have to resort to with cast steel or O1) - just because you have to deal with the burr, etc. Even on diamond, 3v grinds half as fast as harder O1 (thus hones the same amount half as fast) - all of the supposed advantages are negated by screwing around honing and getting cornered into using a specific abrasive.
That long explanation boils down to my guess that the amish can get a 1095 knife and pretty much keep it sharp with a whisper of sharpening here or there, and it's not a nuisance to deal with a burr and no need for prissy sharpening stones that need flattening or this or that. It sharpens on anything and grinds well on hard low maintenance stones.
I thought bushcrafting was about learning to do things with basic tools and being able to adapt to different scenarios.
Batoning seems like the opposite of that. Sacrificing versatility so it can do a specific task in a specific way instead of learning the different methods on splitting a log.
If you want to save weight then replace that big knife with a smaller one and carve some wedges to drive into the logs.
Also, hunters can and do benefit from these steels and their development. I'd reckon it would be beneficial for a hunter to be able to process multiple animals without resharpening in between animals or halfway through processing just one. I'd say that's a pretty good real world situation and not some contrived scenario.
Seeing a 1095 knife in a vice getting hit with a hammer several times and having the knife permanently deform instead of breaking, people are likely to think that 1095 knife is "tough." While, then seeing a 3V knife in the same vice break after getting hit a couple times with the same hammer, and people are likely to say that 3V knife isn't as "tough" as the 1095 knife that just bent. However, by the numbers, that's just not the case.
Yeah, the what-would-you-do scenarios can be a bit over the top but things do happen...hunters get lost all the time....cars get stuck 100 miles from nowhere....planes crash in the wilderness.....walking out in a couple hours before nightfall isn't always an option, and sometimes seeing the sun isn't either. Lots of folks have walked in circles until they died from exposure. Rule #1 when lost is stay put if possible.....What's the likelihood of getting in a survival situation vs. getting in a spat on a forum about a survival situation. Then, beyond that, what's the likelihood of carrying 1095, having it break in a survival situation and dying because of it?
I live in the NE/Midwest transition area (pittsburgh). There's a fair amount of remote area around here, but it'd be pretty hard to die anywhere around here if you just picked a direction from the sun and walked in a straight line. Sooner or later, you'll run into a road or private property.
I'm not a bushcrafter, so visualizing survival scenarios is pretty far out to me. I did cut into a staple in a box today (and didn't know it was there). I think this would've done some edge damage to any edge (I used a really cheap knife and fixed it with an india stone, a deburring wheel and a buffer in 8 seconds over a minute).
Carving out wedges doesn't use up much energy at all. If that's not your thing, fine I'm not forcing you.I don't care about spending precious energy to carve wedges into wood or fancy dumb techniques. Batonning with a knife is effective, fast and energy efficient. In fact, I'd even argue it's more energy efficient than using an axe, less prone to mistake too since you have more control for spliting wood (one big swing vs smaller taps). Managing your energy is a big part of bushcraft, not because of fancy rules, but because it's survival 101.
As has been said, heat treatment is a big factor. For those who think regular 1095 can't be as good other steels, if you don't the name Frank Richtig you should look him up....Later I asked him to do the same with his ESEE3 which is 1095 - part of his edge got pressed in he said.
None of that was damage that can't be fixed in few minutes on a stone but results are rather interesting.
SK5 and 1095 are softer, so they both took some damage.
3V performed as expected, while I didn't think that D2 can cut metal without taking damage as it's known as brittle steel.
I've tried batonning before and it didn't feel more efficient at all to me compared to using a hatchet. Contact splitting and the sissy stick method solves the control and safety issue.
Are you sure you're not the one gatekeeping by making it seem like there's only one right way to do things and discarding all other ways as inferior?
You can prepare for anything you can think of, but how much are you willing to carry? Most places around the NE you really don't need much. A good knife, a fire steel, a small hatchet, maybe some strike anywhere matches in a match safe, a compass, a 9 volt battery or two and some steel wool for emergency fire starting if you absolutely need it.... Fire making material is easy to find. Dry pine needles and pine cones are common and burn well, birch bark generally can start a fire even wet....Electronic stuff doesn't run forever.....a first aid kit should be in your vehicle, it can also help you get a fire going if you know how and its properly stocked.....It raised curiosity for me more along the lines of if you were going somewhere that could happen, what would you take?
I'd have a gps tracking/messaging device. I've been lost in the laurel mountains here before, but it's a matter of inconvenience, like "OK, how dark are we going to let it get before we flag someone down on the next road we come across". What else would I take? paraffin wax or something - a couple of ounces of it so that I could start several fires without having to split kindling (and a cheap buck folder to cut meat). IT's not hard to pick a smooth rock out of a creek bottom and sharpen one of those and bark or stick strop it.
