Most don't dislike trads they tired of hearing how a 6 dollar knife is superior in every way.
[/URL]However, if closing a liner lock feels unsafe to you that is probably because you never took the time to get use to them and that is why it feels unsafe. That's ok though, its just your inexperience showing
I have my Case Trapper in my hand right now, and if anyone says they can open it one-handed with thick gloves more easily than they could with a thumb-stud or opening hole, they are absolutely full of it.
It is okay to like the things you like, but don't make things up to try and justify your preference.
The danger of closing a liner lock ine handed is similar to that of closing a mid lock or lock back one handed. All of these designs require you to have your fingers across the well of the knife while you "break" the blade away from the lock. This is a well understood design issue with liner locks.
When I first saw a liner lock I initially thought the same thing, however after practicing with one I realized that by moving my thumb out of the way I could safely close the knife. I honestly feel safer closing a liner lock one handed than I do going through the gymnastics of opening a traditional one handed, unless you're talking about a traditional like a one armed jack that truly is designed to be opened one handed. If the liner lock was so unsafe I'm pretty sure no one would be designing knives with them, especially in today's lawsuit happy society.
One quick aside and I don't mean to pick on LowKey because a LOT of people do this whenever safety comes up. If I say X is safer than Y that statement doesn't at all imply that Y is unsafe, just that it's not AS safe as an alternative.
I will readily admit that I have no clue how to one hand close a liner lock in a manner that doesn't put a finger or thumb in danger. If you could describe that in more detail or maybe point to a video that would be great.
Note: I'm cautious with mid and back locks for the same reason.
The key is to move your thumb out of the way before you close the blade all the way.......
The folding hunter, trapper, muskrat & probably some others were designed for hunters.I have not read through all the answers but I believe that answer is because most modern people are not outdoors men like those that carried a stockman or a hunter folding knife.
When was the last time you woke up and grabbed the shotgun and went out and hunter two or three rabbits and then cleaned them. Your modern knife can do the job but not as well.
The design of the stockman is for hunting pure and simple and most here do not hunt. We need just one blade for most of our chores. And the other older styles of blades were for agriculture.
Sure. That's true with mid locks and lock backs too. The issue though is that you must hold the liner/frame open while you "break" the blade free of the lock and that means you're forcing a freely hinging blade towards your thumb. And if you get the least bit careless and the blade hangs up on the lock and then lets loose, the blade can swing shut quickly like a sling shot effect.
Every knife forum I've been on has pictures of folks who've been cut in this way.
IME, slip joints and friction folders are much safer one hand closing.
The Stockman was made for people looking after livestock. Skinning was part of it, but it has a spey blade for castrating & a sheepsfoot for paring & pushcuts. Not really a hunting specific knife.
Every knife forum I'm on has plenty of pictures of people injured by slipjoints as well.The problem is that we lack data on frequency and severity of injuries. And reducing modern knives to all liner and framelocks effectively ignores the many, many modern folders that lock open and can be easily closed without placing any body parts in the path of the blade. The huge advantage modern knives have over traditionals is, I think, in the very nature of the two. Modern knives are free to evolve. You can't make a new traditional. It's a contradiction in terms. Traditionals tend to have the edge in terms of cutting geometry, but there's no rules stopping a modern knife maker from matching it whereas if you want a stockman with a quarter inch blade, you're out of luck.
The Zero Tolerance 0808 is our latest piece of pocket technology. It's a collaboration between ZT and custom knifemaker Todd Rexford and is based on his Cesium model. But the technology here isnt circuits and wires. Instead, its advanced-formula stainless steel and ZTs smooth-as-silk KVT opening system.
The 0808s blade is built of Crucible S35VN stainless steel. This powdered metallurgy steel is extremely fine-grained so it can be sharpened to a razor edge. Added niobium and nitrogen enhance toughness to resist chipping and provide excellent edge retention. Yet its also easy to re-sharpen.
Opening is fast and simple with KVT. Caged ball bearings surround the pivot to make the blade quick and easy to open using the built-in flipper. With KVT, the 0808 is as easy to open as any assisted knife, but without the need for a spring.
The 0808s blade is paired with chamfered titanium handles that provide a solid, and very durable, grip. The sturdy frame lock has a hardened steel lockbar insert to offer extra-secure, extra-solid blade lock up. The reversible pocketclip enables you to carry comfortably left- or right-handed. Move over, iPhone. The 0808 deserves pocket space
I still think traditionals are more than enough for the vast majority of us and, if the hardcore adherents of modern knives were forced to 'get by' with traditionals they would be just fine 99% of the time, but embracing innovation has some serious advantages.
