- Jul 22, 2009
I have a custom Emerson Super CQC-6 that I paid over 2k for. I still love it after 5 years but I wouldn`t buy it again. It`s a special knife to me with a special story how I got it.
Mine is a gen 6 Hinderer XM-18 3.5 No-Choil in M390, which ran me $425. It was not worth the money.
The knife doesn't flip unless you use bearings in the pivot, and even then it flips poorly. There's a massive amount of detent rock in the closed position, where you can see the lock bar shifting when you put pressure on the flipper tab. Worst of all, it was ground laughably thick behind the edge (even for a hinderer), which made it a massive pain to reprofile to anything approaching a normal edge angle, especially at the transition between the two flat grinds. I ended up reaching "screw it" levels of frustration and convexing the entire blade in a rage. It now cuts better, but I've effectively ruined my ability to resell it. I'm done with hinderers.
I thought the issues could be fixed easily. I would have if I knew that wasn't the case with this particular knife.Ouch. I would have returned it to the dealer immediately.
That William Henry is interesting. What kind of handle and blade materials?One of them, the other is a William Henry T10-P Lancet.
Here's my WH.
Man that’s really disappointing. I’m looking to pick up a Gen 6 because I heard the flipping action was much better. But now I’m skepticalMine is a gen 6 Hinderer XM-18 3.5 No-Choil in M390, which ran me $425. It was not worth the money.
I posted my 111 a few pages ago as one of my most expensive. Shiro has their own interesting solution regarding that knife's stop pin and the fact that the presentation side is CF only, similar to the 0492 referred to earlier. The pin is affixed to the blade, protruding through the lock-side only. It travels through a chase milled out in the CF and stops in both the open and closed positions against the rather complexly milled, multi-functional liner on that side.Its definitely still somewhat of a question how strong just a peg hole in cf will be over time. WE knives has an interesting solution. They have a fairly thick teardrop shaped piece of metal that fits into a cutout in the g10 or cf. the round part of the metal piece the bearings roll on and the “tail” of the teardrop gives a place for the stop pin to go in and be supported by metal.
I had two. Ever single generation comes with people proclaiming that "the detent is totally different now" and "this is the version that actually flips". As per always, however, they didn't change a thing; they just put bearings in them, and are still putting out knives with inconsistent and awful detents. The bearings are enough to make them open, just poorly. If you use bronze washers like most people seem to want to, then I'll bet you don't have great luck. Though there is a chance that you get one with a good detent, but I wouldn't bet on it.Man that’s really disappointing. I’m looking to pick up a Gen 6 because I heard the flipping action was much better. But now I’m skepticalDo you think you got a lemon?
