Because of comments posted in another thread I've decided to withdraw my offer of sending SODAK my Jess horn to use. I guess I'll just try and sell it or leave it sitting in my drawer. Sorry. It really is very cute to see Cliffs sheep start acting and posting just like him.
Like I already told you in that thread I have already cut the same type of twist ties with an M2 blade that was ground very very thin, much thinner and also harder than either the Jess Horn or the Caly JR. I find it very funny that you just assume the small wire tie will destroy the U2. Unlike you I don't assume that a little wire will damage a hard thin steel edge as much as it does to a thicker softer one. I personally think the U2 would cut the tie with little to no damage. People have been testing edges and yes even thin edges by cutting much thicker metal like hangers and nails for a very long time. SO I guess the scope of work for the U2 is cutting only paper and cardboard. If that makes me a hypocrit in your eyes I guess that is fine. I can take it I've been atact by Cliff and his sheep before and probably will be again. Glad to see you've learned from Cliff how to tell me what the hidden meaning behind my posts are. You learn well.
Yeah those little wire twist ties on toys are edge killers. I even chipped a all hard M2 blade I made cutting a toy out. A small wire cutters is the best for those things.
edited to ad.
That DMT D8xx is worth every cent.![]()
Edge holding is significantly better on abrasive cutting, even though the hardness and alloy content is higher the frequency of problems with chipping is in fact much lower. The grindability is low but since the hardness is high it tends to be easy to sharpen provided the edge geometry and application are sensible.
-Cliff
WOW! Where did I ever say a knife was the best thing to cut wire ties? I think I said in that quote of mine you reposted that small wire cutters were the best thing to cut them. Again you are telling me what I mean in my own posts. Just like you continued to go after me in the other thread more than 2 different posts after Iinformed you I was done posting in the thread. Then you come here and do the same. You don't wander far from the flock do you? I'm not real sure how you have perceived any ill intent or taunting from my posts. I even said I was sorry for suggesting the test but that even had some other meaning according to you. I'm sure Cliff is very proud.
WOW! GunMike I'm sorry . I now see where the problem is if you think that is crying about another non named thread and if you feel that is a personal atack on you even though your not named or even refered to. Kind of like me just simply asking you if you tried cutting the twist tie with the U2 or JH, somehow thats taunting you. I even said I was sorry for suggesting such a thing, and that wasn't even good enough for you. Well I am sorry that you feel that way. Please feel free to ignore my posts and move on.Because of comments posted in another thread I've decided to withdraw my offer of sending SODAK my Jess horn to use. I guess I'll just try and sell it or leave it sitting in my drawer. Sorry. It really is very cute to see Cliffs sheep start acting and posting just like him.
i´d guess zdp is harder so its stronger but when it snaps it snaps without giving a warning because of the higher carbon content and higher hardness, less flexible, is this correct you´d say?
... using high hardness, thin, brittle knives on those little twist ties.
I don't know what you guys are talking about.
But I do use my EDC, to cut plastic wire ties, instead of going to get the snips at work, all the time.![]()
Generally, for metal cutting you want the cutters to be as hard as possible to prevent deformation. The critical point is to have the cutter geometry stable under the lateral forces, or shape it to minimize them directly, or cut in such a way to prevent them. Having the steel softer just means it will bend more under the loads, it won't crack, but it will deform and is just as broken.
Alvin discussed this awhile ago using one of his knives to cut a bunch of wire. You would want to do solid press cuts with a very hard cutting board, mild steel is good. It is really tricky with hollow grinds due to the way they "pinch" in such materials and why in general, unless you have jedi level skills, I would tend to recommend a flat grind. I spent some time cutting up tv cables to check method, you want a very fluid and fairly fast cut. Hesitate and you leave the edge in the cable.
If you are checking knives for durability for such work you had better do a LOT of samples, at least a dozen and make sure you are getting some kind of stable mean/median behavior. Otherwise you are not going to be making inferences on the steel but just the random influences due to method.
-Cliff
If I wanted to specifically name a thread or a person I would have done so in the post.
A twist tie with a .032" piece if steel wire through the middle of it. Not your average plastic Zip tie.
