Sodak,
I haven't decided yet which model but it will come from the Titan Series.I just don't know if I want a small knife like the B06 or if I want to go with the B12,B15 in the larger folders. I wish I could afford one of each! That would solve the problem. Which series are you looking at?
MPE
Its good to see now that the shepherd Cliff has now posted, basically the same thing I have been saying, that cutting a small wire tie isnt such a evil thing after all. The only part I minorly disagree with him on is unless the edge bevel is a lot smaller than .023 wide there isnt any difference between a hollow, flat or any other type of blade grind cutting it.
As for my Jess Horn I thought I'd like it alot by the pics, and the steel was another big plus. But, when I got it and held it I knew I didn't like it at all. Therefore I haven't used it and tried to sell it with no luck. It's a great knife and really the type of knife I look for but it just didn't fit me well.
Generally, for metal cutting you want the cutters to be as hard as possible to prevent deformation. The critical point is to have the cutter geometry stable under the lateral forces, or shape it to minimize them directly, or cut in such a way to prevent them. Having the steel softer just means it will bend more under the loads, it won't crack, but it will deform and is just as broken.
Alvin discussed this awhile ago using one of his knives to cut a bunch of wire. You would want to do solid press cuts with a very hard cutting board, mild steel is good. It is really tricky with hollow grinds due to the way they "pinch" in such materials and why in general, unless you have jedi level skills, I would tend to recommend a flat grind. I spent some time cutting up tv cables to check method, you want a very fluid and fairly fast cut. Hesitate and you leave the edge in the cable.
If you are checking knives for durability for such work you had better do a LOT of samples, at least a dozen and make sure you are getting some kind of stable mean/median behavior. Otherwise you are not going to be making inferences on the steel but just the random influences due to method.
-Cliff
How thin does the edge have to be before the primary grind becomes critical?
Whatever, db.
My Manix was chipped in a similar way to your M2 knife. I was in a hurry to open the toy for my daughter, used improper technique, and chipped it. I agree wire cutters are best used in situations like this. I then used improper technique again and chipped 2 other knives. If I used proper technique I may well have not chipped the Manix or the other knives. I now have a better concept of proper technique for cutting metal, however I got none of that information from you. My inexperience with cutting metals made me a little gun shy about using much thinner and more brittle knives to cut the same metal that chipped my other knives.
Instead of offering suggestions about using proper technique and the proper way to cut metals with knives, you just suggest I use the U2 and Jess Horn. I am reluctant. Then, you spout off how you thought I was into testing knife edges, and you "apologize" for suggesting I use the Jess Horn or the U2 to cut metal. At that point I still had no concept of proper technique of cutting metal, as was obvious by my posts of how I had cut the twist ties. You then state you don't assume anything about how knife edges will cut metal, but you think the U2 will fare fine. If you had offered some sort of example of you using a similar knife to cut a twist tie like that without suffering damage, or anything useful like the technique suggestions Cliff gave, maybe you could have been taken seriously and given me informative and useful advice. All you had offered to this point was that your all hard M2 knife chipped, not very reassuring. Then I am Cliff's sheep. Funny how the only thing you really offer is name calling and a couple anecdotes, but nothing that in anyway would help me to come around to your viewpoint that the U2 would have no problem cutting that metal.
Then Cliff posts, you actually agree with him, almost completely, except for the primary grind type not mattering unless it is below a specific edge width, to the thousanth of an inch. Since you down me for being Cliff's sheep, I figure you must have independant knowledge to verify what Cliff is saying, because you almost always disagree with him, and were specific about the grind type not mattering unless the edge was significantly thinner than .023". You would be one of his sheep if you just accepted his post on blind faith, but you profess that isn't so. I only asked where you learned that from, and how much thinner than .023" does the edge have to be before the grind type matters (in your mind). I also asked about edge angles and microbevels, since you seemed so sure about your knowledge of metal cutting with knives in that post. And by your own statement, logic says you believe the primary hollow grind would be an issue on a knife like the U2 with an edge at 4 degrees and under .005", as most would consider that well below .023". Seemed like a fair question, and as I actually try to learn from reading about what others have done I asked for your references or personal experiences so that I can gain knowledge. If liking the fact that Cliff backs up his assertions with real numbers, science, pictures, and references to verify what he is saying makes me a sheep, so be it. Anyone with half a brain knows the real sheep is the one who doesn't ask for references, and who just accepts a person's statements on blind faith without requiring any proof, just anecdotes and "I said so". To not require any form of evidence or proof of a person's statements is to be naive at best, and just plain gullible. Those are the types that infomercials are made for.
The explanation you then give about the grinds not mattering seems to go off of a lot of assumptions, which you say I shouldn't do about the cutting ability of knives on metal. Yeah, your edge may be a 1/8" long, and the item you are cutting might only be 1/16" thick, but wouldn't it seem an ultrathin hollow grind would chip all the way out to the primary grind easier under lateral loading, while a flat grind with a thicker edge may not? Again we are talking about humans making these cuts, not a jedi level masters, so some minor lateral loading is bound to happen. Wouldn't it then reason that a flat grind may give you a little more room for error, and be a better overall choice for cutting metal? (sorry, I just noticed Cliff's post covering this, but I have already put some work into this paragraph so I will let it ride). This is the type of discussion I was looking for so maybe I could learn something from you, but all you have to offer is insults and B.S. when someone asks you to back up your assertions. You just go on a rant like a child throwing a tantrum when you are asked for any details beyond your anecdotes.
Have fun, and keep on trolling, db. You sure are good at hooking me in!
Quote:
Originally Posted by Dog of War
Wire, even copper when it's bigger than like 20 ga., can be hell on knife edges. I'm sure it's due to lateral stress right at the apex, which is very hard
to control unless you're deliberately cutting the wire held securely on a solid surface and carefully applying force straight down.
Yeah, I still held the twist tie in one hand, looped it around the knives, and then cut, so there was definately some lateral stressing going onto the edges.
When cutting braided speaker wire that was flat on the table there were no chipping issues at all with the Manix, so technique is very important.
No, I don't want you to finance my knife hobby, and if you took it that way you are way too literal in your readings of things. You gave a sarcastic, baiting "apology" , or at least it seemed that way, and I was in a bad mood at the time. I apologize for being pissy.
I think I will test my ZDP Horn (I'm 90% sure I will right now), and I will talk to Cliff, and if he gives the OK I will do the test on the U2 also, probably at a 20 degree microbevel, but only if my Horn doesn't have a really bad experience, even if he does give the OK. He may well call me an idiot and revoke my priveleges with the U2 for asking, but we'll see. Considering the relatively brittle steels and the fact that cutting .032" metal isn't really in the scope of work I pictured for the knives, it seems to me like chopping a cinder block with a ZDP Endura, just way out of the scope of work for the knife and asking for trouble. Why don't you e mail me your address, and I will send you a piece of the twist tie in the mail and lets see how your Caly Jr. does, too. I would be interesting to see the difference in performance of VG-10, ZDP, and SGPS at thin angles. Test to consist of laying the tie flat on a cutting board, then push cutting straight through. Hopefully I can get my sharpness levels up again now that my fingers are a little better, I know I will need it and good control to not twist a chunk out of the edge.
Gunmike1,
Thanks, I'll include it in the test. I'll start another thread about that soon.
... I believe that if he were to post something which directly contradicted my findings and I presented mine with accompanying supportive numbers which were correctly arrived at, that Cliff would at least double check his own and freely admit he was wrong if that were the case.
Similar, I would strongly suggest that the minute you see anyone use a personal attack them you immediately put them on the ignore list, assuming your purpose here is to actually learn about knives. Don't feed the trolls, they thrive on attention, any attention. They are happiest when they drag you down to their level because they know they have no ability to participate at yours.
-Cliff
Well I have been accused of not being much of a critical thinker by a few on this board, but when men like A.G Russell, Chris Reeve, Sal Glesser, (and others), men who are leaders in this industry speak up, I tend to give them the respect they have earned, and actually believe what they say. Their character and past accomplishments have more than proved themselves as the kind of professionals we all can trust. Their words will alweays be golden in my book.It doesn't matter who says something
If that makes me less than a critical thinker, I'm ok with that.
This of course is why you check work because while there is a 5% chance (for example) you might be wrong, the chance that two people will be randomally wrong is 5% * 5% which is 0.25% . So only 1 in 400 times will two such supporting conclusions both be wrong. If you extend it to just a few more people it quickly become basically impossible. This is why it is very important to adopt an approach like gunmike has where he shares his work, finds out what others have done, rechecks, etc. .
-Cliff
