sharp_edge
- Jul 30, 2015
The only ZTs I own are an 0350 and an 0400, and I just checked them. I lightly spine whacked them against the heel of palm of my hand, and luckily they didn't fail. I've had both of them for years, but admittedly I haven't used them much at all. I did the same with my Spyderco Military. Even though the ZTs didn't fail, my Military felt more solid when doing that than my ZTs did, even though at first glance, the Zts "look" stronger.
I really don't habitually spine whack, but tend to use hand pressure to the back of the blade as a test.
Jim
There is actually an easier way to check if the framelock will fail due to negative pressure without smashing the spine. Just lightly tapping the spine when the blade is locked open. If you can hear the noise of metal hitting metal (that's the lockbar or lockbar insert contacting the blade tang), increasing the strength of tapping/whacking will most likely disengage the blade. If all you can hear is the sound of the spine hitting the surface, then the knife is good to go.
