If "modern" includes mostly 30 year old knives, or newer Randalls, then definitely.
Maybe the metallurgy is right while the CPM steels are wrong...
A 1999 test in Knives Illustrated pitted CPM 3V, and another CPM steel, against 440C: 440C was
miles ahead in every medium... That was a test with purpose built test mules, so I do consider it more credible.
All the knives that did well -for me- were 1980s vintage blades in Aus-6, D-2, 440B, 440C, and the 1940s unknown French stainless. All of these ranged from 30 to nearly 80 years old... Only the Randall Model 12 in 440B was of recent vintage and performed very well.
One huge recently made Voorhis bowie in 5160, at 12 degree per side on a 0.020" edge, damaged easily while chopping, until I opened the micro-bevel to around 22 dps: It is passable now, still with a less than 15 dps/0.020" REK main edge bevel on an 11" blade. I don't expect as much from Carbon steel, given the extreme ease of sharpening, so the quite open micro bevel and relatively fast dulling are acceptable to me: The ratio between edge-holding and ease of sharpening I consider passable.
The near 80 year old French knife had very mild, barely visible, edge warpage in two places after chopping Maple, but then it was only 0.010" and 10 dps (REK regrind), so obviously way too thin: I just wanted to see how good this nearly 80 year old stainless steel was... It made fun of all the CPM I've had the misfortune to buy. If "modern metallurgy" includes this 80 year old knife, then yes, they did know what they were doing.
I don't know: 30 degrees does not look that impressive to me, but I did note that when you baton, then yes 30 degrees is a
big problem, with deep micro-folds all over the edge in 5 baton hits to split a 2" stick, while 1000 chops did nothing similar...
The implication of your wording is.... Stainless does
worse than Carbon in resisting damage, while chopping at thin 30 inclusive angles. That would presumably be
less dream like... Did I actually read this?
No, my eyes must be playing tricks on me...
Annnd... My Randall Model 12 (440B), my Lile "Mission" (D-2), My Al Mar "Special Warfare" (Aus-6), never existed throughout their hundreds of chops over two years, all documented with photos when Photobucket was around: Got it.
Well at least one of those was a Survive! GSO-10 with a bone-stock factory edge, but then these are known for their sloppy edges, right?...
I did take several picks of my nail material hanging from its edge after less than ten chops: Left side on the forward part of the blade, right side on the rear when I hit with the rear...
Did you actually
read my posts? You know... The thing about
constantly rubbing the nail to detect invisible micro-folds, which I seem to be the only one doing with my nails, and then taking pictures of the scrapped-off material, always hanging to one side and not the other?... Not to mention talking about it around fifty times per post?
Which nail rubbing nobody here ever talks about, preferring instead to talk of how the edge
slices paper...
Yes,
slicing paper: Or better yet:
Shaving arm hair! That, I have to say, is my favourite, although hair-whittling is not bad either...
Gaston
