- Sep 5, 2006
Yeah that helped it a lot for sure. Now the lock doesn't seem to have the room to slide all the way over. Thanks alot Stabby!
Yes we deserve to know the truth, sometimes the truth is hard to find. I suggest sending the knife in when you are ready.
One other question: what's the pivot tension like?
On a CQC-12 I had, if the pivot was loose, the lock-bar could easily go almost to the other side.
When the pivot was tight, the lock-up was good, and didn't move much at all.
Basically, the loose pivot allowed the blade to tilt a tad, making for a very flat surface for the bar to slide across (ramp tilted till it was straight across, pretty much).
Glad to hear it was a quick and easy fix. I'm very curious to see the effect it will have on the lockup of some others that posted. Shipping knives with a loose pivot isn't the best QC, but it's a whole different planet from shipping them with bad locks.
Almost forgot, thanks for starting the thread. It might have taken a whole lot longer to turn up a solution without it.
Lets be fair though. We dont know if it loosened with use or if it was shipped that way.
Lock up now after pressing the same, also it unlocked easy. The like factor for me on this knife went up for sure.
Yaaaaaayyyyy!!! Who woulda thought a snarky Canadian would solve the problem?
(just kidding, stabbers!)
I checked and snugged it up a bit and it seemed to help.
Good work stabby! You solved the problem and you get to keep both hands! But get no knife![]()
I think he would say there was no question![]()
Would've been real nice if you had've mentioned that in your first post :grumpy:
I know you were only holding back because you didn't want to slow a good thread down![]()
