Porter
Can you do me a favor and tell me whether or not your motor is a face mount type. If it is let me know the spacing between the bolts. I would like to make this for a face type motor and need to know if yours is the same as mine.
Chris
I plan to now use a 56c face mounted motor exclusively.
Chris
PS If your with me say Aye
Are you talking about carrying the entire weight and vibration of the machine with just a motor mount plate?
If that's the case, then it will not be rigid enough.
I might just be misinterpreting this though![]()
Ok look at the sideshot, I recently made the upper arm longer than it was in the beginning so that one could either put a 3 inch coil spring between the tooling arm box and upper arm(Like a KMG)(option1).
That's a Compression Spring
Or one could put a spring like the one on your screened in door at the end of the upper arm to the body of the grinder(Option 2).
That's an Extension Spring
Tell me what you guys are thinking, I dont like the idea of the long rear spring because it would prohibit the tooling arm going to far to the rear, but maybe leaving the option viable is a good choice.
