Well rescued some steel from the local flea market yesterday and had time to get it back into working order. The lady I purchased from seems to usually have a couple of gems tucked away and she is always game to haggle. This rusted piece of carbon steel is an Old Hick 8" slicing knife. Very cool with some definite "trade knife" looks to it. Here is the before with the double bit I rescued for a later project on the bottom.
Edge had pretty much rusted off of it, but there is some life in there... First off a good long oil soak to break things (dirt, grime, rust, etc) up. With heavy rust like this you can use other products to break it up, but I was going to be bringing it to the grinder anyways, so oil works perfectly for cleaning it up, and starting the "restoration".
Next take it to the sink and scrub it up, started with a chore bore stainless mesh scrubber, then a scotch bright pad, then a scrubbed with a magic eraser, heavy soap and water the whole way from tip to butt. Patina is still there cause there is a big of pitting, but most of the active rust has been washed away.
Next time to take it to the 2X42! Because I was intending on using this in the kitchen I decided to go ahead and thin the knife out, plus it was pretty wAvY from corrosion, so I thinned, brought up, thinned some more, etc. Basically trued it up on both sides, then threw a quick even edge on all with 80 grit. Also had to regrind the spine to true it back up and get the tip/point back. Plus I went ahead and rounded the handles, and reshaped the butt of the knife to my suiting. Then took it to the buffer and hit it all up with some green compound, and used a wire wheel on my dremel to get all the hard to reach places knocking off the last of the rust. Getting there...
Finally convexed out my edge, hand stropped it up, impregnated the handle with my skull wax concoction, and even decided to put some artsy fartsy burn marks on the handle. They may not stay but for now they reinforce the "trade knife" look. May have to make a sheath for this guy ended up liking it a lot.
A functional and rough and tumble looking blade.
