Hey
Fish, did you ever find out whether or not the second charger that you received which didn't light up works? Mine doesn't light up either, but I tested the battery with a volt meter and it read about 5.3 volts and it worked when I plugged it into the "turbo" pack unit. However, I haven't used it since that day I turned it on a few times to test it out, and I just turned it back on today and the power supply seemed good/normal for about 15 seconds, but now it all of the sudden seems like it's extremely low powered, because the fan is barely running and I can definitely tell a difference.
All of this "testing" was done without the filters on in yet, just to make sure they weren't a variable.
Maybe it just needs a good, solid, full charge, but I just now checked it again with the volt meter, (which is about 15 minutes after testing it and the fan running pretty low/slow) and it reads pretty much right at 5 volts, maybe 5.05, but you get the idea. So it's a bit lower, but it seems like it should be running as low powered as it is.
Is it possible for the battery to give off a small "jolt" of power for the first few seconds after turning it on but then returning to it's actual power level (low) after the battery has rested, or not been used for a little while?
Anyway I figured I'd check with you (or anybody else here) regarding your charger that doesn't light up to see what to expect if I tried charging it over night. I don't know if it doesn't light up because the prongs on it haven't been cleaned or lubed (although they don't look or feel dirty), or if the light itself on it just went bad and the charger still works or what. I DO know that when I first tried charging it for a few minutes, that the charger became warm, so "something" was going on, I think! lol.
If it's not already obvious, I'm pretty much completely ignorant when it comes to wiring or anything electronic etc. etc. so please forgive me.
So that is "my" update regarding my Breath Easy system so far. Everything seems to work great, but I'm not sure about the charger and now I'm not sure why the power is running so low while the battery still has 5 volts... maybe that is about when it needs to be recharged due to lack of power??
Thanks for any and all help or suggestions.
~Paul
My YT Channel
Lsubslimed
(It's been quite a while since I've posted any new vids)
