Dr. Thor said:He showed a tree being totaly dismantled by a Cold Steel Recon Scout,
With a small assist from the saw. That knife did right good, though.
This is only an issue if the handle is rubber, or wood or something that can't stand the impacts, and you are concerned about the grip material failing. The steel itself should never fail regardless of where you hit it with a piece of wood. In order for this to break the impact toughness of the steel would need to be near the as quenched level.Peoria46 said:I a longer blade allows one to baton both sides of the blade, thus reducing stress on the handle.
Cliff Stamp said:The steel itself should never fail regardless of where you hit it with a piece of wood.
-Cliff
Franco G said:. Compared CS Recon Scout and Fällkniven A-1, which one is supposed to be thougher?
Franco G said:Questions for Cliff, everyone:
2. Compared CS Recon Scout and Fällkniven A-1, which one is supposed to be thougher? I guess Recon Scout, because of carbon steel (assuming a neither one is a lemon).
Franco
TLM said:Lets state it this way, if you are afraid to hit the back of the knife with a wooden baton, how do you dare to hit a log with your axe, the situation is kind of symmetrical.
4 Ranges said:Steeldriver et al, my point simply is that I think the RS is a fine knife for OTHER It's misleading to state that a particular knife fails "miserably" simply because it can't do ONE THING.
Thomas Linton said:Just a note. Several here have described the SRK as 5/16" thick or as thick as a Trailmaster (5/16"). CS site says SRK is 3/16" thick. That is corect, right - 3/16"?
Say what??? One can pummel a knife spine with great exuberance, yet fear striking the handle. Admittedly less fear for a full tang than a hollow handle.
yoda4561 said:I think you may be a bit confused in regards to the acronyms. SRK does not equal Recon Scout. The SRK is a 6 inch, 3/16 thick small clip point fixed blade, way smaller than the Recon Scout is at over 7 inches of blade and 5/16 thick. The RS/Recon Scout is basically a shorter version of the Trailmaster, same handle, same construction, same steel, etc.
DaQo'tah Forge said:If there is any doubt as to the use of a tool for a job you need done, I would suggest you just write or call to the maker of that tool,,,(be it a hammer/knife/screwdriver,drill etc) and ask them if they intended their tool to be used in that manner....
SethMurdoc said:my question about wether or not an ax really is better in that situation (pointed towards Nutnfancy or cliff or anyone who has done this kind of work a lot (cliff lives in a winter wonderland from what ive seen))
wich will tire you out faster, battoning with the rsk, or splitting with a hatchet?
also, can you use less force with the hatchet in your swings and still have it function properly? specifically, will the hatchet get wedged into the wood moreso then the knife, resulting in the need to extract it from the wood forcefully?
