- Jun 16, 2003
shpshooter said:Personally, I believe a hatchet is better in that situation. A knife can really only be used for batoning (not always, but generally), however a hatchet can be used for batoning and for chopping, striking, and the "lift and slam" method. As a wood chopper/splitter a hatchet is the better tool.
Many would agree. And so? The issue is the knife. Was it so unreasonable to use it to baton or was it so misused in batonning (or otherwise) that the failure is excused?
shpshooter said:More can be done with it [hatchett] and when chopping the strongest part of the head/blade is what impacts first, unlike a knife where if you are chopping it is hitting with a weaker part.
????????? You hit butt first when chopping with an axe?
shpshooter said:Also, typically hatchets have a larger angle (greater wedge) so it will go into the wood slightly slower, but will split faster.
Seems true so far as I know. This is why proper technique in batoning a knife may include using wood wedges to overcome this problem.
shpshooter said:Many times people talk about using the right tool for the job, I would consider it the right tool for the job of splitting wood.
Many would agree. Not relevant. Steel wedges and a maul are better than an axe. A splitting maul is also better. A power splitter is even better. The knife is an accepted tool to accomplish the task and often expressly designed to accomplish the task. Why did this knife fail on this occasion?
