- Feb 27, 2010
I see some here have concerns with wear/longevity. Get a fixed blade....plus who are you kidding...like anyone here will only have one knife forever.
I am so tired of finding a knife I might like only to find it has the latest stupid fashion; BALL BEARINGS! This is less than a useful "feature". IMHO ball bearings in a knife is a design flaw. Knives are to be used and not to be made for the feel of the opening. When did he smoothness of opening a knife take precedence over its ultimate utility? Many of the knives I would have ordered immediately otherwise have been disregarded and put into the ignore pile for life because of this stupid fashion.
I know I am going to get people tell me differently and call me narrow minded, but if you use your knife in real circumstances then ball bearings are going to be a problem. Ball bearings are going to accumulate crap and get sticky and gritty. Some designs have been failing out of the box because the point contacts of the balls causing brinelling or denting the surface they ride on, and they require frequent and sometimes tedious disassembly and reassembly procedures to keep them clean and lubricated.
C'mon manufacturers! Stop making fashion knives and make knives that can be relied on to work in conditions other than just flipping at the desk when bored.
I have degrees? When did I say that?
I have extensive experience as a heavy industrial mechanic, and mechanical engineer position, and scientific instrument design engineer, automotive and motorcycle mechanic, and machinist
Nobody with an ounce of common sense in their brain can deny that ball bearings are a structural downgrade. I said structural, not "functional"
Just look at the pics posted earlier, the bearings eat tracks into the titanium, it's just a fact. Sure, it wont do that if all you do is sit at your computer on bladeforums.com or the couch flipping your knife, but use it hard enough and long enough - and it will. I'm speaking from first hand experience, i had ZT's on bearings that did it and i sold them all off, won't ever buy a bearing knife again.
So, a man who makes "the standard by which all other tactical knives are judged" is now suggesting that ball bearings are a HUGE step FORWARD in design and functionality.
aka "SELLING"
The scale in that photo shows galling in the milled bearing race.With regards to the above in bold. Whether you cold role or cut the raceways (like below) it is part of the design. If it is done properly your knife should not give you much issues.
aka "SELLING"
It's generally a waste of time to try and convince the "other side" that they are "wrong" (You, of course, being "right.") You could try to present a rationale argument for your position, as some have, or you can rant, which tends to put off those who are undecided.
I know that bearings are used for bikes and cars and am sure that they run in environments all dusty and gritty. How can they perform without an issue? Because they are well shielded? If so, I would wonder if we can have a sealed pivot with bearings.
Miso
Full disclosure: I have not owned a ball bearing pivot knife and never will. I have extensive experience as a heavy industrial mechanic, and mechanical engineer position, and scientific instrument design engineer, automotive and motorcycle mechanic, and machinist. I have camped in the forest and the desert. Dirt is everywhere.
A foundry is probably one of the worst industrial environments you could ask unprotected ball bearings to survive. So you just need to blow some compressed air through the knife and squirt some special oil into to pivot. Do you have access to a compressor and oil in the middle of the desert? How about just after gutting a fish for the fire by the stream? Should you need to clean and lubricate all the time? My washer pivot knives never have had grit get into the bearing surface causing it to stick.
It is simple. A ball bearing system costs much more to implement than just a couple of washers. Washers need a drop of oil and off you go. I don't always have a compressor with me wherever I go. In high load low speed applications, plain bearings (washers) are highly preferred over ball bearings. It is an engineering principle.
aka "SELLING"
