fillers making it rock in the divot pneumatic pressure plays a part also in the divot. I'd say..Sando said:The Visual Test
JB Weld tho fails this test (in my opinion because it'll be really hard to make it seamless - the stuff is thick and has fillers.) I can't explain why only one side showed a seam. The wood was flat. Maybe it tilted a bit, 'cause it just doesn't thin out.
Dan Gray said:one of the problems when over claming is when the two parts are not flat
you cause it to be it's own spring forcing it self off.
flexing type will be the best if used right I think because of expansion
do you know that aluminum expands almost at twice the rate as cast iron
I can only guess on other materials..mechanical is the way
but I see your point
but not sure what the point is if mechanical is best and the other is for sealing only..![]()
other than, if the steel is cupped ( crown out from the wood) this will spring it still with one contact point on the clamp..Sando said:No kidding, I've suffered from that too! That's the reason this test only has one clamping point for each block. See I've thought of many things for this test.
Sando said:BTW I'd appreciate questions about why, rather than "you should have". For example, "Why are their two holes in the bar?" Or "why are they all on the same bar?" Or, "what the heck is U-05FL?"
C L Wilkins said:OK, what the heck is U-05FL???
Craig
howiesatwork said:Loctite U-05FL Metal Bonder
Hysol® Two-Part Urethane Adhesives
Have High Impact Resistance and Highly Flexible Bonds
These two-part urethane adhesives cure at room temperature. They feature large gap fill, low temperature performance, long term UV resistance, and high oil and solvent resistance. Easily dispensed using the hand-held meter mix dispensing gun (415-260).
Expensive.
You mean like potassium nitrate plus sulphur plus charcoal powder? Now THAT is a toture test!Bruce Bump said:I have always liked JB Weld but ..... I add black powder to it.
