- Feb 11, 2016
@traumkommode you certainly didn’t take the easy route! Welcome.
@traumkommode you certainly didn’t take the easy route! Welcome.![]()
I really like what you did with that knifeYeah, not sure about "easy", but definitely "fun" and "deeply satisfying".
Cheers!
OK, so I am totally in love with this knife! Jack must have known I am a Gemini, because this two faced Lambsfoot is a perfect knife for a schitzo like me
View attachment 845684 View attachment 845685
What a great slicer, and the Big'uns fit my hand like they were made for it. I've had a lot of fun with this one already, listening to its raspy song as it sings its way through paper and cardboard. Love the point for tracing cuts, and even pocking holes in sausages to let 'em leak out while they sit on a hot grillI could see myself getting a regular, (smaller) version to play with or carry as a secondary knife, they are pretty addictive lil beasties. View attachment 845688
Guardians, I've been admiring your fine knives for a while, and I finally post to ask for consideration for Guardianhood. May I present to you my latest work, and a rare one, being 1 of only 1 ever produced: a GEC produced, Welsh (that's me) ground #15 Lambfoot knife with a 440C blade.
I gave the spine as much downturn as I could and still open the knife without widening the EO notch, since I had to loose the nail nick.
What a TERRIFIC blade.
Here's a "Before" shot:
My big Stag and my evening snack!
Bore da! It's good to see you here, and you really put some nice work into that blade. Maybe it is the angle (I tend to stand off when taking pics, so as to try and avoid capturing my own reflection), but while the blade is now very different, it still looks like a Sheepsfoot to me, the edge of the blade seems to be parallel to the spine. If I'm right, it looks like you'd have to take off a fair bit more steel to turn it into a Lambsfoot, which you might not be able to remove from the spine, and you might be better leaving it as a great-looking Sheepsfoot
Unfortunately, you're right. I measured, and it's parallel. That was a parameter that I overlooked. I think there is enough blade for me to angle the spine down and still open it, but I would basically need to grind of the top of the swedge. I wonder if I could cut a nail nick with the wheel on a Dremel if I secured the knife to a surface...
Dicey call either way. It still opens really nicely now. And I would take opening not as nicely for Guardianship. But I wouldn't take opening poorly for it, I would just try again on another knife.
I'll think about it![]()
@traumkommode what’s the pull? With the EO you won’t need much real estate that far from the pivot if the pull isn’t too much, perhaps?
My three A Wright knives.Many thanks to strokednbored out of Austin Texas for his patience in guiding me with very well made diagrams through the steps. Much appreciated brother.![]()
Lambsfoot! ^^^^^ @traumkommode
Even a Yank can see that.
@traumkommode I think you nailed it this time![]()
I admire your skills at knife modification, I'm not that brave, kudosThanks Rob!
What is that smaller pattern in the middle? Is that just the pruner pattern and the two others the standard LF?
Reason I'm asking is from the looks of your picture the middle knife looks a bit smaller in lenght than the other two. And according to the A. Wright web page they are the same lenght, the pruner LF and tha standard LF that is.
