- Sep 13, 2017
Very nice vehicleThanks for the kind words. It’s a 1985 Toyota 4Runner.
What does the zinc anode do?Regular diving knives are known for having extreme corrosion resistance and ZERO edge holding properties... LOL. They work much better as ballast than as cutting implements. I have bent a couple trying to brain some tough fish.
Right now I carry a semi-DIY diving knife I made out of as skeletonized blank that I slapped two slabs of home-made micarta on it and bent some kydex for the seath. It is getting rust spots but I rather deal with that than with a dull edge. It needs some attention but so far it works.
Some brands make diving knives with a sacrificial zinc anode attached to the blade (or you can do it yourself, wedging a smal piece in between the handle and blade in the ricasso area (easy to do with rubber handles). This should protect the blade until the anode erodes away and then you just replace it. You can carve/grind a small piece out of a boat anode leftover. They should give it to you basically for free in any marine supply or marine mechanic shop.
If you want to go high tech, I think the only solution is to increase the budget and get a fixed blade from the H1 line of Spyderco. I just bought a Fish Hunter, should be here in one or two weeks... and I will need to bend another kydex sheath for it (the stock one is not suitable to strap it to your calf).
Mikel
What exactly were you whittling...?![]()
Ha!
I like how you think.
Sharpened my son’s 119 up today. He has harvested many deer so far and loves it. I do too! Such a great classic design and performer.
I must say I don't quite like the looks of this line of Buck but everyone says it is a great design and solid knife (for hunting purposes at least). Being no hunter at all, and using my blades more for general utility or wood works, I usually favour the full flat grinds (or full convex) more.
What sharpening means do you use with such a big array of knives put into use in a daily basis? Do you use paper wheels or any other power fancy equipment (Worksharp, Timken or something) or just plain old freehand on stones (be it natural, ceramic, diamond, etc)?
Mikel
Is that a bk15 in a kydex sheath? If so, where is the sheath from?
Did a little off-roading to a secluded beach this morning. Carried the Kershaw Dividend in the surf shorts to handle Musubi cutting duty.
We will see how the steel and liners handle salt water.
View attachment 1431538 View attachment 1431539 View attachment 1431540 View attachment 1431541 View attachment 1431542
