Production K390 knives are averaging ~64rc.HRC only matters in context of the performance at a given HRC. It might *only* be 63hrc(which in itself is not true, the hrc is going to vary wildly), but if it's getting k390 edge retention at ~67-70hrc, then I don't care what the number is.
I meant will 63 magnamax be getting similar edge rentention to ~67 k390(which k390 is a bad example, so substitute anything else). and making a point that the hrc really only matters in context of the performance at that given hrc. 63 is plenty hard enough, but whats the performance at that hardness. because at the end of the day all i care about is edge retention. corrosion resistance is just an added bonus to magnamax but not the draw for me. that's why i like 15v so much, the edge retention.Production K390 knives are averaging ~64rc.
MagnaMax will not be able to achieve 67-70rc with production HT.
MagnaMax is designed to match the corrosion resistance of MagnaCut which is extremely high.
Previous steels with high corrosion resistance (Vanax,LC200N) were stuck at 60-61rc.
Chromium in solution limits maximum hardness, it's a trade off.
So, it is an innovation to have finer carbides than K390 and serious stainless abilities with higher hardness than previous nitrogen stainless technologies.
I was at BladeShow 2025 and was talking to Bob Skibitski the senior metallurgist for Crucible now working for Erasteel.All legitimate data points are useful. That's how things progress. There will always be outliers and anomalies.
If we did a controlled test 67 HRC K390 will cut longer than 63 HRC MagnaMax which should be no surprise.I meant will 63 magnamax be getting similar edge rentention to ~67 k390(which k390 is a bad example, so substitute anything else). and making a point that the hrc really only matters in context of the performance at that given hrc. 63 is plenty hard enough, but whats the performance at that hardness. because at the end of the day all i care about is edge retention. corrosion resistance is just an added bonus to magnamax but not the draw for me. that's why i like 15v so much, the edge retention.
magnamax is set to be a huge thing for knives, a stainless with that much edge performance is a novel thing and not to be understated. i am very excited to see what we're working with in a year or two time, when companies have had a chance to dial in their processes and get a wide variety of models out there.
Man, if I didn't show up to blade and show Bob that edge he probably would have believed that other guy. I mean technically, that material was not designed for something like that.Spark hasn't approved moderators keeping forum members after class...
...yet.
Its really a great service to have people like you and larrin here on the forums to educate the plebs like me. It's not every day you can get educated directly by the brightest and most experienced legends in the field. Thank you for everything you do for usIf we did a controlled test 67 HRC K390 will cut longer than 63 HRC MagnaMax which should be no surprise.
Controlled test meaning that we control for the same geometry at the edge and grind and they are being cut the same with a fixed amount of cuts on a fixed load with the same media.
What we'll usually see is that carbide type and volume are the biggest factors followed by hardness.
The carbide volume of K390 and MagnaMax. It's technically the same.
Carbide type Is similar (MC).
That much of a hardness discrepancy and you will notice that the K390 will cut longer in a drag race.
However, what if you're cutting something acidic? What if the edge is being exposed to corrosive sweat and what if the edge is experiencing impacts?
There's certainly some caveats where it could take the lead in the scatter of real world uses.
Well I appreciate that, but it's not like I was born knowing any of this stuff either, I appreciate your engagement on the forum. It helps bring out good information for others to read and I'm sure you've helped plenty of people. Lot of this stuff is not very intuitive and it takes the minds of many to help contribute.Its really a great service to have people like you and larrin here on the forums to educate the plebs like me. It's not every day you can get educated directly by the brightest and most experienced legends in the field. Thank you for everything you do for us
MagnaCut was supposed to make M4, CruWear, 4V and 3V obsolete... yet it didn't happen sadly. (Sadly, because if it did - MagnaCut would have trully amazing performance).Fingers crossed that MagnaMax really does make K390 obsolete.
I don't know if anything could make anything obsolete with us knife nuts around.MagnaCut was supposed to make M4, CruWear, 4V and 3V obsolete... yet it didn't happen sadly. (Sadly, because if it did - MagnaCut would have trully amazing performance).
I do have a MagnaCut knife, and I really like it's performance, but I use it as my sea knife, and for stuff that really does stress the blade - I still reach for 3V...
this is a solid truth, least with me.I don't know if anything could make anything obsolete with us knife nuts around.
We will buy them all.
so youre hot for teacher thenBlues needs to see me after school
I think of all the education that I've missed
But then my homework was never quite like this
Have you seen his knife collection?so youre hot for teacher then
a few of them...not the whole collection. nice stuff that ive seen.Have you seen his knife collection?
Soorya few of them...not the whole collection. nice stuff that ive seen.
btw, thanks for taking all the fun out of my joke off your joke.....
