- Jan 28, 2007
I still want to know:
Is it ok to lube the ball bearings? 1 of my Tilts is noticeably less smooth after tightening the blade play out. I would imagine that lube would free it up.
Shouldn't be a problem, I've used Eezox on my RAZR with no issues.
If it isn't smooth, the issue is more likely over-tightening, or the detent ball riding over the blade.
Try pushing the lockbar away from the blade so the detent ball doesn't touch, if it is still rough and there is no blade play, then try reducing the pivot tension.
You should be able to adjust the pivot to the point where it just takes out the play. Any tighter than that can feel rough (even though the knife will still flip open easily), and can lead to faster wear of the bearings and faces.
Make sure you only adjust the pivot in very fine increments, the point at which the play disappears is kind of abrupt.
Worst case scenario, take it apart and make sure the surfaces the bearings are rolling against are smooth and flat. If the pivot tension ever got cranked down way too much it is possible (but unlikely) that the bearings left impressions.
