Large Survival Knife vs. Hawk
brother 'punishment - i hear ya on the value of the khukri - i think i'd be turning the kukhri around though and tend to use it for clearing, and the hawk for finishing, and switching the tasks back and forth erratically.
man, fights suck, but that'd be a good one if you had to go in style.... :cool::thumbup:
My kukri is to heavy for that. Unless the other guy is swinging something as heavy, or is just slow, I wouldn't be able to keep up. Kukri are just as "stabby" as they are "slashy", and make one hell of a huge would with just a quick stab while you have the other guy's weapon busy with the hawk.
that said, i don't really care about the larger swath khukris make, i'm not going to need that in the field for my bushcraft, and it has got to have lower PSI than a hawk bit at the same weight, so i am still sold on small-bit hawks, as long as they have proper hawk physics.
Well, it depends on the kukri model. If you have one with more of an upswept tip (less "stabby"), the sweet spot is at the middle of the curve, and not much edge makes contact with what you're cutting. If you're going to stick to wrist-size or smaller wood (proper 'hawk wood ;) ), even my low-PSI Ang Khola with go through in one or two swings, depending on the wood. It's also got the longer edge, so it does machete work as well. I know you carry a machete to cover that option, but what attracted me to kukri was that I could replace the hatchet, machete, and BFK with one tool. The reason I picked such a heavy kukri of such length is that one of my criteria is that it had to chop as well or better than my 19" hatchet. The fact that they can cover all those bases, and the users/makers are smart enough to include a small knife for detail work makes them a "survival system" of their own. Nothing else is really needed for outdoors work, living or survival.
if i could only have one, the khukris would be a great choice though.
nothing wrong with them IMHO, they just don't "sing" for me.
give me that swept bowie instead.
vec
They aren't for everyone, just as hawks aren't for everyone. We have to pick the tools that suit us and how we work the best. A few of us unfortunate souls learn many ways, and many tools, and you end up like me with a whole friggin room of gear and "sharp stuff", all of which you have organized in kits that can "do everything", depending on how you want to go about it that day.
We really gotta do some choping comparisons with hawk and kuks of EQUAL weight.
That would be interesting, but it's really not a great comparison when you limit one tools to the other tool's design point.
That'd be like me saying "Let's compare my kukri to bowies that are 20" long and weigh 3.5 pounds."
Instead try doing a task the way a hawk is designed to do it. Then try to do the SAME task the way a kukri is designed to do it.
I think what you'll find is that BOTH work, when used properly, and it comes down to user preference on which you prefer.
I like the PSI on a hawk too for getting deeper penetration into wood than with my kuks. Maybe I should think about reprofiling my kuks as a lot of you guys seem to be getting better chops with the kuk. We really gotta do some choping comparisons with hawk and kuks of EQUAL weight. Vec, I agree on the PSI thing, that's what really turned me on to the trailhawk when I first started using it. I was amazed at how well it chopped. But, I got a Fort Turner hawk made to my specs and I'm really loving it. The blade is a bit longer which helps me avoid misses on wood, but I still get a lot of PSI due to the slight angle of blade down and in towards the handle (think Francisca, just more utilitarian). I'll try and post pics soon, but I'm liking it so far, and it is as light, if not lighter than the trailhawk. Next one I'll see if FT can use 5160 for it.
they are definitely all good tools - we should never get too heated about which is better IMHO.
i'd really like an industry standard that, when an item was sold, the weight, balance point, length, and stock thickness (at least) were shown, with at least three perspectives on the tool.
there is also no accepted standard on what a knife or tomahawk is, or even a khukri - all of which can change drastically in performance with small, sometimes invisible, design modifications, such as change from carbon steel to stainless, changes in the material on the butt of a handle, etc.
i think if you have no patience and no idea of how to maximize the use of a proper hawk in field tasks (among other factors), and you tend to get overwhelmed in combatives (no shame in that BTW IMHO, not everyone is a fighter), the khukri is the better choice (by a hair) - but a lot of people seem to be good at hurting themselves with a khukri IME, compared to novices with hawks; this is really key to me in tool selection, because i often teach bushcraft to females and small people - to me handing them a khukri is like handing a novice shotoer a .50 BMG and saying go have fun. - they might have fun, but they are potentially going to be injured, and they won't be effective unless they are some sort of chopping idiot savant. - meanwhile, a light machete and proper long hawk, with a couple minutes of how to hold the hawk especially, turns a novice into something formidable in the woods, as well as in a fight, ...and that what i personally am interested in - a tool or tools that is very general purpose, and a little on the light side - plus redundancy doesn't hurt, hence my appreciation for the "two fister technique" of having a hawk and a machete.
....so going back to proper classification - when i say "proper hawks" - that is a tomahawk that weighs about one ounce per inch of its length - anything ten percent more or less is a differnt animal, often a forest axe or Belt Axe one way, and what i would consider a battle-specific hawk if you went lighter. - people pick just about anything up that is relatively light with a head on it, that has completely different characteristics than a hawk, then they (commonly) add their ignorance of hawk techniques - which i find critical to using a hawk to one's satisfaction, and they have a bad go of it and then decide hawks are no good - when they never touched a proper hawk in the first place. :(
brother 'wolf - i like the field knife and hawk combo too, and i usually have the field knife on my belt gear for when i separate from my larger tools and shelter for just going and getting water, etc. - but the long knife or machete is not replaceable in the combination in most instances outside of combatives IME, because the short machete or long knife is so good for making snow shelters and wind walls, etc. (for me, at least) - i can't be completely contented without a long blade. - that's another reason why i don't favor the khukris - i use the stabbing feature a lot on my long blades, particularly horizontal stabs, when making shelters, and a tip-heavy khukri tuckers my old bones out a little too soon in that regard - sure, there is always a work-around, but i prefer bowies or machetes for that task, amongst others.
still, it must be repeated, they are all good tools - they are the best ones, in fact IMHO - i'd be stoked to be stuck with any one of them singly, and pleased as peaches to have a combination of any of them in the field.
we owe it to ourselves to be very familiar with all three, the proper hawk, long knife, and khukris.
vec
One point I haven't seen anyone address yet.
The differences in handling characteristics and weight even between knives and hawks of even similar design.
as an example. I have two M-43 kukris from H.I. One earlier model made by Bura with the original style handle. And one by a different Kami with the new style handle and a thicker spine thickness. There is a difference in weight and handling characteristics between these two blades. Though both share the M-43's trademark liveliness in hand the Bura made blade is faster and lighter.
I have two forged bowies from the same maker. The first one I had made is 16 oz. very lively in the hand and is an excellent blade for fighting/defensive applications. The second is 19 oz. Has a ompletely different feel and is better suited to bush use. And this is in two blades with nearly exactly the same profile.
My point being. One needs to gain experience with several designs of any of these tools before one can really know what will work best for you. I settled on the M-43 kukri after experience with other kukri types and some research into the design criteria of that blade. Other kukri's do not perform the same or even similarly to it.
The same goes eith Hawks. A Coal Creek Forge hammer poll hawk with an 18 inch handle will act completely different than a modified CS trailhawk on a 24+ inch handle.
The M-43 served me exceptionaly well in many environments over an extended period of hard core survival living. From a survival standpoint I couldn't have asked for a better tool. Minly due to it's lending itself to such a wide variety of uses. It even made a great sickle for cutting bedding material.
As to the combative aspect. One strike from the kukri or a bowie is all I've ever seen needed to fataly end a confrontation. Unfortuantely I never had the chance in combat to see a hawk in use as none of the men in my unit at that time carried one. ALL of us carried and used large knives however.
I personally like to carry both a Hawk and a knife. My combo on many a hike has been my Great River Forge Medium French hawk and Becker BK9. Have done some splitting with the French hawk, but not real chopping as of yet. Am thinking that a longer handle would be nice so if I can find a good deal on the 30" Hawk handle from Cold Steel I'll probably get it and cut it to the length I want.
Earlier the Hawk VS Khukri was mentioned. Here's my take on it: In my hands, my hawks can not out chop Most of my Khukris. Sure the main wait on my hawks is in the head and most are around 12oz but my Khukris start at around 22oz and I've been using them for 9 years now. Hardly used a hawk so I'm tons better with a Khukri. Mind you I'm talking about chopping wood, mostly elm, willow, Aspen, Cotton wood, scrub oak, lodge pole pine and ponderosa pine. As always, your milage may varry. One of these days I should do a chop off between my French hawk and 20" Sirupati. Wonder what those results would be like. Bet they would make a good combo.
Heber
respectfully, brother - what kind of hawks and khukris do you own that weigh that little?
my BUG hawk heads weigh 11 ounces, plus the weight of the composite handle itself, and Trail hawk heads alone weight about 14 - 15 ounces, in stock form, plus the weight of the handle.
and what type of true khukri weighs 22 ounces? a CS khukri machete? - the next one must be pretty tiny, or a lot heavier, by my reckoning.
it sounds off to me.
TIA.
you have to define "outchop" too, to be clear and fair - since most wilderness tasks are not race-based, and some of them aren't even endurance based - what wilderness task is it, in your view, that a khukri is better suited for regular carry than a proper hawk?
- i don't think there are any wrong answers, so don't take my questions as implied criticism. - i like khukris a bit as pseudo-machetes.
vec
Hi Vec, I've been using Khukris since 2001 and my go to blade is a 20" Sirupati that weighs 22.5oz and has about a 12.5" cutting edge (called Lisa from here on out). I've cleared miles of trails here in Central Utah for service projects, I've chopped wood, cut brush and cut up tons of food on campouts. Got my first hawk in 2008, a French hawk by Great River forge that I though the head weighed 12oz (Specs on his website for the Medium French) but turned out to weigh 16.5 oz. Haft weighs 6oz for a total weight of 22.5. That was a shocker this morning. Anyways the French hawk came with a 90 degree edge that wasn't sharp at all. I've used it a few times and it was horrible. Didn't really cut, more of a smash through things and not very well at that. I fixed the edge and chopped on some 3 to 5 inch thick dead standing scrub Oak and the results weren't very promising.
Lisa has cut 3 to 5 inch scrub oak with less chops. I figure that the ammount of chops in a given tree is a good test. Same type of tree, same thickness, less chops with Lisa means better to me. Again I have very little experience with a 4" cutting edge Hawk VS tons of experience with a Khukri with a 12.5" cutting edge at the same weight. My experience with a hawk is almost nil but my experience with Khukris spans 9 years, many miles of trails, back yards, and so on. Of course I'm going to be better with my Khukri then my hawk.
All I was trying to get at with my first post was that do to my experience with a Khukri I'm better with it. But that I want to work with Hawks more and get the experience to be good.
As for the light Khukris Wolf pretty much covered that. But I would like to add that my 16.5" WWII is about 21oz, Lisa is 22.5oz and my old 16" Gelbu Special was somewhere between 12 and 16oz so I've seen a few lighter Khuris on my time playing with them. Of course my 18" ASTK is 42.7oz and out chops any blade I've used except for Godzilla which is 25" Long and weighs 5 pounds .5oz.
So Vec, I'm not saying you or anyone else is wrong, I'm just saying my experience with my Khukris VS my 22.5oz hawk with an 18" handle is limited and different. But willing to accept that it will probably change as my experience grows.
Heber
I can say that with my larger, broader khukris, I can go through a vine or branch the diameter of my wrist with one clean cut. No other edged tool I have ever owned can do that, at least not as effortlessly as a khukri.
Heber
i appreciate the input, brother.
at the specs you just gave, your Khukri fits the spec for what i would call a proper hawk - since it must have about an ounce of weight per inch of length, plus or minus 10 percent. - i bet it would be interesting to see the strike zone on that blade, to see how wide it actually is. - some of my early Gen 1 Mk 1 hawks were going through 2-inch saplings repeatedly up in the frozen Canada - i attribute that largely to the users' expertise, but also the ergonomics on our Gen 1 Handles, which are absent in standard egg-shaped cross-sections on hawks and axes.
there is no disputing that khukris are formidable choppers and unsurpassed as a combination tool, as well as good at other field tasks when modified or cutomized (even given their predicament of coming in a wide range of shapes and weights and lengths that perhaps makes discussion of them as a group a little less than scientific in nature, they all typically perform well, given their elemental characteristics of mass placement, etc.).
i'd like to vectorize some khukris myself, to milk their design a little more for my own personal use.
alrighty - time to go feed the velociraptors....
great thread, great thread, great thread.
vec
you've never used a scymitar, i reckon.
when i go to North Africa, i am definitely going to bring some back.
vec
vec
Definantly a good thread! Now I really want to put a 20" to 24" handle on my French hawk. Bet it would be an awesome blade!
Over the last week or two, some one has been dumping tree trimings in the alley way behind my apartment complete. Provo City doesn't mind me going back there to trim bushes and trees that are in their right of way. Thinking I should take some Khukri's and hawks out there for a little practice.
The last few days of following this thread have got me thinking about what Khukris I could pair with a hawk. Probably a Sirupati like Lisa or my 15" 16.3oz Sirupati, Gelbu Special or a Chitlangi. Another blade style that I thought would make a great pairing with a proper hawk is a Machete.
Heber
Personaly I carry both...
I just reaceave a Survival sheath system haress made for my ATC tomahawk, and my Spyderco Forager+ a CRKT minimalist.
its esat to carry and very efficiant.
Whne I don't whant to carry a big blade like the forager I just change it for my Cordova 4" survival.
crossada,
Please tell me about this tomahark haft... I 'haft-a' know!!!
crossada,
Please tell me about this tomahawk haft... I 'haft-a' know!!!
'not brother crossada, brother - but that's one of my early Gen 1 Mk 4's with a Micarta Veneer SnakeSkin finish.
BTW - the head is a pure fighter variant of the Cold Steel Trail Hawk - note the abbreviated poll - they are really viscious in poll-forward combatives.
HTH.
vec
thanks for the assist Vec:thumbup:
that finish has a nice grippy surface to it but not so grippy that it gives you hot spots. It also has the stadia lines in front that is nice and smooth where your fingers wrap around. Perfection!
i really like that micro-pebble feel on the skins - it reminds me of wearing gloves almost, but with the sensitivity fof bare hands.
i love it when an idea actually works.
LOL.
v
I agree, this is a really great thread. My interest in blades took two new directions while following the posts here: a) tomahawks; and b) bowie knives. I bought a custom CS trailhawk from blade man, and have a Gen 1 Mk V composite handle with BUG head on order with vec. But I really went crazy with the bowies. Have CS Natchez, CS Laredo in SK-5, CS Laredo in San Mai, Ontario Bagwell Gambler, Ontario Bagwell Helles Belle, and Ontario Bagwell Stealth. The three Bagwells were bought as a package deal and I plan to sell off the Stealth. I may also sell off the Laredo in SK-5. Got a lot more than I really need that's for sure. :D
Whadaya expect from a feller born in Lafourche Parish, Louisianna and raised in San Antonio, Texas, home of the Alamo. I've got bowies in my blood. :o
where did you find all the Ontario stuff HDW?
and that is a big bowie haul for sure. wouldn't know what to play with first:eek:
I'm jealous, that is an impressive collection of bowies! I'm itching to get the Natchez, what do you think of it?
