@Terdl76 recovered that one for me, he has an artist eye for sure.
I don't know all the engineering behind it, however I would say yes for sure with the calf pen. The spring is very firm on its own, if you hold the lock to the side and operate the knife if performs just like any other slip joint.just out of curiousity, can a liner lock be removed and still have a functional
Slipjoint?
If the up coming GEC stuff doesn’t catch my eye, maybe I’ll try to find a calf pen and get it just where I want it, via modification.
ive never re-covered a knife before, but this seriously makes me want to give it a try. I re-handled an Opinel And that worked out well.
Slipjoint?
Now if I could get up the courage to potentially mess up what is nearly a work of art in its own right...If it is next to one of the scales it shouldn’t be a problem. If it also serves as the middle liner then you would have to make a new middle liner.
agree after a few try outs with the bail, but just can't recall a GEC folder with a lanyard hole...
Offhand I remember my 42, 73, and 83 all had lanyard tubes
I think some of the F&F line have lanyard holes.
The #47 Viper is another non-F&F GEC that has a lanyard tube.
The #99 Farmer Lock and #65 Farm & Field & Fish knife have them, too. I could be wrong, but I think the only F&F knife that doesn’t have a lanyard tube is the recent #62 Pocket Carver.
On the F&F line it is strictly a cost thing. It doesn't answer your question though.wonder if knife producers avoid that because of strength concerns?
Consider, for a moment, how negative this post is. GEC makes bail-less knives by the thousands, year-after-year.Disagree. All GEC two blade and larger bail / chain knives were manufactured with an engineering mistake ... the additional blade makes them too wide to fit through the bail that was designed for a single blade. The bail gets in the way anyhow, but adding a useless bail is an unforgivable mistake. Dumb. Stupid.
Agreed. I'd love to see one even smaller than the White Owl, actually. We've seen GEC produce varied sized of patterns (#18, #22, etc.) and there are certainly historical examples of cigar patterns smaller than the #68. I'd love to see such a patter come out of GEC in the future. Fingers crossed.im all for a smaller equal ends cigar pattern knife. cmon single blade 35!
I don't know if this is easy or not, however this is what happens when I get bored.
Well I’m not Jiki, but I have a pretty easy one for you. You can use a stick of any dimension. The idea is to skin a stick, cut that stick in half, then make two square notches that lap together. I happened to make a cross because... well... either way you cut it it’s going to probably be some kind of cross. Use it as a religious symbol, crucify mice, use it as a marionette handle, turn it into an airplane, use it as a study tool, or make a picture frame by using 4 sticks and Cutting 8 notches. If you get it right, the joinery will hold together without glue, as you see here. A really good job is making such a tight joint it makes minimal gaps (impossible to avoid completely due to curved surfaces).
What kind of wood is that?Well I’m not Jiki, but I have a pretty easy one for you. You can use a stick of any dimension. The idea is to skin a stick, cut that stick in half, then make two square notches that lap together. I happened to make a cross because... well... either way you cut it it’s going to probably be some kind of cross. Use it as a religious symbol, crucify mice, use it as a marionette handle, turn it into an airplane, use it as a study tool, or make a picture frame by using 4 sticks and Cutting 8 notches. If you get it right, the joinery will hold together without glue, as you see here. A really good job is making such a tight joint it makes minimal gaps (impossible to avoid completely due to curved surfaces).
Love that ChurchillWell I’m not Jiki, but I have a pretty easy one for you. You can use a stick of any dimension. The idea is to skin a stick, cut that stick in half, then make two square notches that lap together. I happened to make a cross because... well... either way you cut it it’s going to probably be some kind of cross. Use it as a religious symbol, crucify mice, use it as a marionette handle, turn it into an airplane, use it as a study tool, or make a picture frame by using 4 sticks and Cutting 8 notches. If you get it right, the joinery will hold together without glue, as you see here. A really good job is making such a tight joint it makes minimal gaps (impossible to avoid completely due to curved surfaces).
It’s a branch that fell from a red maple tree in my front yard. It’s fairly weathered, which made it more tawny than the typical less attractive grey it tends to get as it oxidizes. My 2 year old gave it to me. I’ve made a couple light/fan chain pulls from it, and what you see here.What kind of wood is that?
