Blade HQ ran this test on the knives. Any surprises? I thought the Esee performance was disappointing, and the cryo a pleasant surprise. I didn't realize lock backs were so inherently strong.
https://www.youtube.com/watch?v=4KmHfbG7z7g
I like it.
Any test tells you what it tells you. What this tells us is strength as it relates to straight closing force. Important, yes. But not the whole picture.
What the test doesn't tell us is what happens when there is closing force at an angle, which can deform the frame faster than straight closing force, thus causing the lock to fail faster. Would love to see the test redone with the knives held at 45 degrees from vertical.
Another thing the test doesn't tell us is durability UNDER HARD REPEATED OPENING PRESSURE. My experience is that most lock backs can develop significant vertical play when used for repeated hard cutting and over time, this vertical play gets worse. A key issue is how to stabilize the blade and lock bar as the blade presses back against the pivoting lockbar. My Opinel, which probably has a closing fail pressure of 14 lbs, has outlasted all of my lockbacks from several manufacturers in this manner. I suspect that frame locks have the edge among the groups tested here.
