Maybe because I have fooled around with knives most of my life, I have discovered several things that the end user can do to take care of some of the problems that knives may have. And I do certain things to most all of my knives upon receipt.
One of the primary things I do is to disassemble the knife, clean all of the factory lube, seems to be a light grease on the Kizer, off of the liner's, washers, and blade. I use Miltec to lube when I reassemble the knife. While apart though I will put a little more bend in the locking liner, linerlocks/framelocks, to get a stiffer locking bar, and to increase the liner pressure on the closed blade. I suspect when people send a knife back to the factory for a weak detent, that this is what is done by the factory. Every one of the knives I have, that are linerlocks or framelocks, has had this done to them. It does not take much extra bend to get the desired results. Been doing this since the first screw together knives came out, and have never run into a problem. And have never had a locking liner to move across the blade tang at an accelerated pace. Remember, just a little will do!:thumbup:
