I thought my thumbstuds were loose, and I tightened them up so that they won't come off. I also bent the liner because I "thought" that it had some blade play, and now the liner locks up in the middle of the blade tang. I also tightened the pivot.
We live with the circumstances we're dealt with, and sometimes the hand that we are dealt with sucks, but there are better, more fulfilling ways of getting reparation than just going on the Internet and proclaiming far and wide why a product fails when it hasn't even been through the "ringer", so to speak.
I may not personally know these guys, but I will give them a first shot at making their product right (should anything go wrong)
To each his own. Respect each other's rights and choices, not be preachy and almighty and trying to force your own views down the majority's throats!
By the way, my Strider still isn't perfect- but I'd bet my life on it and I wouldn't have it any other way!!!!
i have never understood how emerson and strider seem to inspire either undying love or pure hatred, nothing in between,
Punisher, I hope you don't think ill of me, but I also misunderstood your post. The part where you said...Hardheart,
I assumed you read my post since you quoted me, but I may not have clearly expressed what I meant. So, categorically stating, THERE WAS NOTHING WRONG WITH MY STRIDER KNIFE WHEN I BOUGHT IT. Lock-up was rock-solid, the opening/action was smooth. THERE WERE NO ISSUES WHATSOEVER.
Like I mentioned, I'm an inveterate tinkerer, and in my PERSONAL CAPACITY, I couldn't leave well enough alone, that is why I "TWEAKED" my knife to my personal preference. Again, there is nothing wrong with my knife, I just wanted to personalize it, hence, I did what I did. In hindsight, I didn't have to, but I'm glad I did, because I discovered how superbly engineered a tool it is.
... made it sound like there was a problem that you fixed, but I see that you said that you just thought the studs were loose, the knife had blade play, and that the pivot needed tightening. Not that those things were actually true, you just thought they were. So don't be too hard on Hardheart, he wasn't the only one who misunderstood your post.I thought my thumbstuds were loose, and I tightened them up so that they won't come off. I also bent the liner because I "thought" that it had some blade play, and now the liner locks up in the middle of the blade tang. I also tightened the pivot.
The pin i am refering to is the pin that sits in the blade itself.
I would not call it a double-sided thumstud, as the oval opening in the blade works much better to open the knife.
I was only holding the SNG in my hand while surfing this forum, opening and closing it now and then, as it suddenly fell out of the blade.
This pin by the way has no thread on it, just 2 marks on it in the middle that seem to be made with a pair of pliers.
When i disassembled the knife earlier to fix the lockbar that wouldn't lock, i did not touch this stop-pin.
By the way, there is also a model SMF on it's way to me as i write this, i do hope STR did the quality control on this one,
I find this whole subject really odd as I pretty much come to two main conclusions. One, the talk of shoddy QC has to be over-rated, or ,two, there are A LOT of really stupid people out there whom have a pile more money to burn than me! I just don't see how a company could consistently be this bad and continue to sell very expensive knives to what is generally a small market segment without some major backlash. And if they ARE that bad, WTF is wrong with people? From how I see it, you got a dud and hopefully, it'll be made right in quick time. Good luck.
I think you won't believe this........
A few weeks ago i received a brand new Strider SNG.
First thing i noticed was that there was no lock up, when the blade was completely opened the lockbar did not touch the base of the blade.
As a result the blade could rock back and forth.
I corrected it by disassembling the knife, and bending the lockbar quite a bit further, so after reassembling the knife did lock up well.
However.....
Just a few seconds ago the stop pin fell out of the blade.
I don't know what to say, and i am truly speechless,
David, I think what he was saying was that he thought there were some problems, and maybe after he fixed them, he realized that he didn't need to fix them because the knife was actually 100% perfect when he got it.I misunderstood as well....i still dont understand....how can you be forced to bend the liner if there isnt a problem? And doesnt saying "now the liner locks up in the middle of the blade tang" imply that it did not lock up porperly prior? If not, perhaps stop using the word "now" to describe things that havent changed.
This happens to me all the time in other areas. For instance, I go to a restaurant because I think I'm hungry, but then after I eat, I realize that I was wrong - I now realize that I feel perfectly full. I just thought I was hungry before I ate.
