osprey888
- Apr 25, 2013
What knife/model is that?
Yes. Me and Yoko both have TSPROF setups.Does anyone use any TSPROF sharpening systems? I have always hand sharpened for years but I wanted to get a system to try out to dial in exact angles so I ordered a Kadet Pro.
I already have and use Venev resin bonded stones so I will just be loading those in to the system to see how well they work in that application.
I will report back when it arrives with some results and pics!
*** I got the KO3 when they were quite a bit lower than the price they are now.
Ko3 is a great system! I have a kadet as well. I only use the Kadet on small blades. Always at the mercy of how symmetrical the blade was ground with these guided sharpening systems.
I've been using a TSPROF KO3 for years and have been extremely happy with the system. I've put some freakishly sharp edges on my CPKs with it.Does anyone use any TSPROF sharpening systems?
I've been using a TSPROF KO3 for years and have been extremely happy with the system. I've put some freakishly sharp edges on my CPKs with this.
I touched up my behemother recently to 24 dps and it can cut smoothly & cleanly through a held paper towel and cleanly pop hairs off my arm. I give high praises for fixed angle sharpening systems, and TSPROF is some of the very best. I'm sure you'll be happy with yours.
I have a hapstone think the model is the R2Yes. Me and Yoko both have TSPROF setups.
The K03 is great (as are Venev plates)!That great to hear! Have you been happy with it thus far? I looked into the K03 as well but figured with my first guided system, I would go for the Kadet first!
Awesome results! Do you opt for the K03 for larger blades just because you have both and it’s a larger sharpening system or do you feel like the Kadet was too small? I do plan to sharpen up to some ~6-7 inch blades but most will be folders and smaller fixed blades.
I'm going to have to check that outI've been really tempted to buy one of these KMFS Vantaedge sharpeners just to play with it. They have a pivoting head design that is supposed to maintain the same edge angle even through the belly and out to the tip, clamp position theoretically doesn't matter. They handle up to a 9.5" blade without changing the clamp, so pretty good capacity and the build quality appears to be top notch. Just not a lot of info out there on them.
Very interesting design and the price seems good. Please lets us know if you get one and how it works.I've been really tempted to buy one of these KMFS Vantaedge sharpeners just to play with it. They have a pivoting head design that is supposed to maintain the same edge angle even through the belly and out to the tip, clamp position theoretically doesn't matter. They handle up to a 9.5" blade without changing the clamp, so pretty good capacity and the build quality appears to be top notch. Just not a lot of info out there on them.
