- Dec 1, 2012
Just because something can be used for multiple purposes doesn't mean it should.
But clearly this thread is about batoning now anyways . . .
A gross oversimplification. Mors does not seem to fit in either category. http://www.cliffstamp.com/knives/forum/read.php?5,3463Some words of wisdom from Jeff Randall (post 87)
. . . as practically any thread in my memory involving damage to a batonned knife eventually devolves to. In fact, we have two topics going on here . . . (1) the efficacy of batonning with a knife, (2) the inflated "survival" claims of a knife . . . ANY KNIFE . . . with the specs of the BlackBird. ....
I don't quite see it that way, nor do i have anything against batonning. I just don't see what the OP was trying to accomplish by hammering his entire blade into a tree stump.
I also argue that proper axe technique requires proper chopping block, a tall order in the middle of the bush with no chainsaw.
Neither do I. But the BlackBird's designer didn't say you had to use proper batonning techniques if you're going to baton his knife. He just said you could baton with it . . . period. And I'd suggest that even with improper batonning techniques, the OP would have been hard pressed to break some of the knives mentioned in this thread . . . unless, of course, he tried to remove his knife from the tree trunk with a winch.![]()
Maybe the OP was trying to do something like this?
[video=youtube;N-WuP-xYlnc]http://www.youtube.com/watch?v=N-WuP-xYlnc&feature=player_detailpage[/video]
. . . as practically any thread in my memory involving damage to a batonned knife eventually devolves to. In fact, we have two topics going on here . . . (1) the efficacy of batonning with a knife, (2) the inflated "survival" claims of a knife . . . ANY KNIFE . . . with the specs of the BlackBird. Most people will focus on the former. I, however, prefer to concentrate on the latter.
To each his own.
But just to get my personal views re: batonning out of the way, should you baton on a knife? No. If you're in a survival situation and the only tool you have to split wood with is a knife, should you be comfortable knowing that you could baton on your knife if you had to without damaging it? Yes.
There is one other topic we could strike up here and make it a complete triumvirate, and that's the issue of doing your homework BEFORE you buy a knife based on manufacturer claims. In this regard, forums like BF and the work of certain members . . . some of whom are here and some of whom are sadly missing . . . have been and continue to be absolutely indispensible.
I'm not sure why batoning is popular all of a sudden. Who started doing this anyway? I was always taught that a knife is to cut things. Not "process wood" with. And that you were supposed to take care of your knife. If you did, it would take care of you.
I suppose everyone just wants to be able to brag that they have the toughest knife made. Well, that's fine, but you certainly don't have to have a knife that withstands constant battoning, to have a tough knife.
I have been going on camping trips for over 40 years. In the semi desert of south Texas, and in the Appalachian mountains mostly, and I have yet to find myself in a position to have to chop logs into kindling with a knife. The knives I have used have all done a great job at what they were designed to do. I try to take care of them too.
I have either used a hatchet, an axe, or a saw, if I wanted kindling. Most of the time, I just pick sticks and dead branches up off the ground.
Can someone please tell me when you have HAD to chop logs up with a knife?
I know of one manufacturer who has changed the steel offered in one particular knife, just so it would withstand battoning better. But that steel is not as desirable as what they moved away from. I imagine many more manufacturers will be going this route in the future. I sure hope not.
IF I was EVER stranded somewhere in the wild, and only had a knife with me, damn if I would be beating the blade with a log. Or rock. That knife would be too important in getting my butt back to safety, to risk breaking it.
If you have one of the knives touted on this, and other forums, that is known to be able to withstand battoning, believe me, you keep it up, and sooner or latter it's going to fail. It's just a matter of time. Where will you be when that happens? Will you be depending on that knife to get you back to civilization? I hope not.
