- Oct 5, 2011
So is this about best overall tool or simply best HT? As you said chad2, it is your particular HT protocol that draws the fire. Keep it simple and no Huckleberries need apply.
Hey guys... I have no ponies in this race, as I don't work with 5160, but...
Two different knives made by two different makers is not going to be a reliable test of HT. Even if you use the same "pattern", you still have variables like edge thickness and geometry. If you want to test HT (and HT only) I recommend the following:
- Knives are ground by one {skilled} maker capable of grinding nearly identical blades.
- The maker who grinds the knives is not one of the heat-treaters... nor is he affiliated with either one.
- The maker provides the material (5160) or at least ensures that the blades come from the same barstock. This will help avoid potential arguments about fixing the contest by supplying dissimilar quality steels.
- Testing volunteers test both knives at the same time.
May the force be with you.
If your only testing the H T ,why grind at all?Just H T two lengths of barstock and break them .
That's what I was thinking. Just heat treat two pieces of steel the two diff ways and send them to a lab to see if the freezer method has any advantages over a traditional ht. because in the end that's all people here care about. If you make a good knife that's awesome and we are happy for you. It's the freezer and 11 day process that no one agrees with so why not cut to the chase and do the testing by a real metallurgist and cut all the amateur testing out.
Because that would be too scientific, and what do metallurgy labs really know? They don't make knives. They just analyse steel 5 or 6 days a week. That can't compete with cutting 2x4's, or the use of a torque wrench. Silly man!
Leethal Cutlery--having never sent anything to a lab to have it tested, what lab would you recommend, what are the names of the tests you would recommend and what do they test for, and what do you think the cost would be?
