I've been reading thru this post and several others... and after a while of contemplation and finding the right deal, I finally have a 'like new' Shin in my hands. Fit and finish seem to be very nice, however there is something that is really bothering me on mine. When the blade is closed there is quite a bit of 'wobble' or movement back and forth. It's not noticeable when open, however if you twist on the blade you can feel a bit of 'play' in the blade. The only other folder I had which felt like this was a mid-tech which had been abused like crazy. I bought this Shin secondhand in as-new condition. Is this normal? The blade and edge seem to be perfect and never used. A very sexy folder, albeit VERY slick in the hand. I think the handle slabs could use some texture of some sort and I don't really want to put skateboard tape on a $1K knife.
Mine is ZDP and # L364
I just hope I didn't get a knockoff... it appears to be genuine w/box and all appropriate paperwork. No screws are loose and in fact I was trying to loosen and/or tighten the screws on the back of the spine and when slight pressure was applied to my tool it was almost twisting my torx bit so I stopped before damaging the screws. Any ideas as to why the blade play is there or is this common on the Shin models?
In what direction is the play when closed? If the blade has play up and down (as in the motion it would move in if you were opening it), that would be detent play and could be because either the detent hole is too big or the detent ball is pressed in too far. If the play is lateral when closed, that just seems like loose tolerances in the pivot. The pivot could be loose but it's very difficult to access on the Shin.
