- Jan 26, 2012
They have all the latest fad "super steels"
Nope. Most are good old S35vn, increasingly more in fact!
This is the new ZT 0909. The LINER LOCK is thicker than the G10! If that is not overbuilt then I don't know what is. The information in this thread about liner locks and frame locks not being strong is just absurd.
The issue I had with mine was not that the lock couldn't handle it... It could. The issue was, with these new steel inserts, the lock slips and disengages. The lock was perfectly fine, no bending etc, the frame lock didn't break. It slipped.
Hey lads... Calm down lol. I am not meaning for this to be a scientific experiment. I just wanted to see if the ZT 0620 would handle what the Griptilian did. There are many factors that I could of change, and honestly it was a stupid test. But, I thought hey... why not share my experience? I trust my ZT 0560BW with my life and yes, if I held the lock It probably would of taken it and not slipped etc. I was just merely reporting my experience flawed as it could of been. I still love ZT's.
That tip is pretty thin to be used for prying. And stabbing into wood and pivoting would cause a lot of knives to break the tips. Knives are for cutting. ELMAX also isn't the toughest of steels.
That's not a thin tip. Try looking at the tip of a Para 2 or a Military....or a Delica. The knife in the pic above does not have a thin tip. I bet you'd have a tough time breaking that tip. I don't mean putting in a vise to break the tip......I mean under normal use....heck even under "hard use". That's a pretty chubby tip.
The thread was silly from the beginning. I'm always baffled by people who straight up abuse their knives and are then shocked when it breaks. I mean, prying... why? Get a pry bar. They're readily available and some small enough to carry on your keys. Batoning... why? Unless you're in dire straits, there's really no reason to baton with a folder (at least use a fixed if you HAVE to baton). Use the right tool for the job. Get a hatchet or ax. Don't go beating on a folder, regardless of the manufacturer, and not think there won't be detriment done to the knife.
The very point of the tip is thin. That's all I was saying
I looked at that tip and it sure looks thin to me when compared to the rest of the blade. Other knives may have thinner tips but the ones mentioned are thin all along the blade.
If that ZT had more of the meat of the blade in the cut then the tip wouldn't have been loaded up and it would have been fine.
If you're going out for hard use; no half measures!
It slipped because you were not using the framelock as it was intended.
Not sure what you don't understand about your HAND gripping the frame helps ensure the lock does not slip.
Your test is invalid at best and something I am not allowed to say here in gennie dee at worst.
He said he did the same with a Griptilian and it's fine. Isn't the Griptilian's tip thinner than this ZT?
Exactly. A valid test would be to first wrap tightly the handle of a frame lock folder with some paracord to mimic hand gripping. Then one can spine wack the knife all day he wants.
They dont have the greatest lock geometry, blade geometry, engineering, heat treatment, and are not even very tough.
