Here is the response I received from CRK:
"We are aware of the concern from customers but there are no plans to change the design. Lock rock, or vertical blade play, is when a lock begins to move vertically. Unsafe vertical play happens when a lockbar isn't fully engaging and there's a little space between the end of the lockbar and the tang of the blade. This isn't the case with the Sebenza 31.
When applying force to the spine of the Sebenza 31's blade, you will feel some vertical movement. Rest assured, your lock-up is secure. This movement is the lockbar flexing in response to pressure, though the ceramic ball, acting as a fulcrum, will maintain its position against the blade tang. It is very much a sound lock and when put to the test, proves stronger than the heat treated lock on the Sebenza 21. All of our models with ceramic ball interfaces have varying degrees of lock flex so this is not abnormal, though the Sebenza 31 seems to be under extra scrutiny as it is the newest.
All that being said, we do take customer feedback seriously and appreciate you relaying your concerns. Please let me know if you have any questions."
