- Apr 5, 2015
Hey wiredbeans, what system are you using for sharpening? I have a sharpmaker and have achieved moderate success on my Spyderco blades but I just bought a Lionsteel SR1a and am having a tough time putting a decent edge on that convex blade. Any suggestions?Here are my 3 mirrors, I can't get a good angle for the camera to pick up the edge
Victorinox Polished by Frans van de Kamp, on FlickrNeeded sharpening after some minor chipping in the micro-bevel, once again, ~7.5dps freehand on a Bester 1200 -> Suehiro Rika 5000 -> Naniwa Junpaku 8000 -> Naniwa Specialty Stone 10,000 progression on the edge bevel and Spyderco F rods (15 dps) to form an apex micro-bevel .
Very nice... how do you find the edge holds up at that geometry? what uses do you use it for and when do you notice blunting? I bet it cuts like a demon![]()
My EDC uses largely consist of food prep, cardboard container break-down, and the occasional clam-shell package, so any geometry that leaves the edge ~0.010"-0.015" thick at 1/32" back from the apex is plenty strong enough for my EDC uses, with any damage being confined to microscopic chipping in one section of the microscopic apex bevel.
The rate of blunting is slow enough that I can keep the apex touched up using very light (as in less that 10 grams) passes on my Spyderco F rods for some time, since I rarely have to use the knife so much in a single session that it gets worn past a touch-up being practical (unless there's micro-chipping or whatnot).
Push cutting ability is faintly silly really, way past the point of practical benefit unless you were literally planning to use the knife as a straight razor, but given my tendency towards clumsiness I really appreciate being able to put as little force as possible into cuts, so I like the combination of very high push cutting sharpness and geometric cutting ability.
KC Hobo by Frans van de Kamp, on FlickrThose are some outstanding bevels folks - great work!
Question to Steel_Drake: After all that work up to a 10k waterstone (likely less than 2 microns finish?) you use a coarser ceramic for Microbevel (likely about 6 microns). Any specific reasons? Do you want a bit more "bite/aggression" with the final touch?
Thanks!
There are two parts to that answer:
Firstly, I am somewhat limited in my choices of abrasives for creating microscopic apex bevels because I strongly prefer to use solid abrasives like Spyderco sintered ceramics rather than any type of friable stone for this purpose. It's much easier to create a very sharp apex when you don't have to worry about the apex smacking into abrasive particles in a water or oil slurry on top of the stone.
Secondly, while the Spyderco F sintered ceramic might be rated at 6 microns, when used with very light force, it leaves a significantly finer scratch pattern than the 6 micron rating would suggest. I would be inclined, based on observing the scratch pattern with a 50x optical/4x digital zoom USB microscope, to compare it to an ~8k Japanese synthetic abrasive when used with very light force. I could use the Spyderco UF rods but I'm concerned about the microscopic apex bevel created in 10-20 passes not having enough depth (i.e. being excessively fragile), and for reasons that are a bit obscure, I haven't tended to have the best results using Spyderco UF stones.
Besides which, the push-cutting ability is already way above any practical necessity, so I see no need to trade off any more slicing aggression to increase it further.
Kissing Cranes Hobo Knife by Frans van de Kamp, on Flickr
Chris "Anagarika";14926383 said:Byrd Cara Cara 2. DMT C, F, EF, EEF, Spyderco UF, green compound on Washboard.
Thanks, makes sense to me. I too noticed that unless I go from the brown/gray stones to the F to the UF on the Sharpmaker, the UF alone does not do a good job for a mircobevel. I also have the feeling that I get more of a burr than anything else - I agree, it is somewhat obscure!
I can see your concern about "cutting into loose abrasives" at the final step. Have you tried stropping on Balsa with CBN or Diamond? It seems to leave a nice and still aggressive Micro-convex.
Thanks!
