Out of curiosity, do you have a chemical analysis of your steels, particularly the W2?
You just want to help everybody here which is amazing and will be useful for anybody facing similar problems. Thank you!I am just trying to make a good knife and I was hoping I could help others by divulging my methods but it seems like this thread has devolved into a nitpicking crusade to find fault with my methods. I think my methods are sound and I think theyre getting me to my destination but when I read some of these posts I wonder what your motivations are.
Like Jens Schuetz stating that the scientific method doesnt only mean one variable. All you are doing is eliminating multiple variables that have no influence to ultimately get to the point where you have one variable which is where I am now. By your own words, Do 2 of them and the remaining one.
If you want to nitpick my methods and argue meaningless minutia go right ahead but Im going to ignore those kind of post from now on and the people that really like me just want to make a better knife I will respond to.
Thanks, Jeff. Next time I'll make sure to make it more clear.I apologise too that I misinterpreted your intention.
For any new makers watching the thread, can you elaborate on why you would expect full (or near it) hardness from a 9 ish second oil when you only have less than a second to cool the steel?
9s oil = cool a work piece thickness to 100-200F. It will works if quenchant able to cool fast enough to avoid the pearlite nose and continuous cooling fast enough to avoid bainitic transformation. So for a very thin W2 cross section (blade bevel), even warm canola can fully harden it because it met both condition above. Sure, spine and thicker section won't fully harden in this case.
That is why I always do a brine test because I consider that my control which I compare my deviation against. So even if the volume of oil that I use isnt giving full hardening it doesnt matter because that same handicap applies to my control so it basically is nullified.
Maybe the quench volume does matter... I don't know. However, volume may make a difference depending on the quench medium. A pint of oil may not have the same effect as a pint of water due to the volume.
Another thing you keep mentioning is that agitation doesn't matter, as you only have 1/2 second. As I understand it, the quench medium is what helps you cool fast enough to get under that 1/2 second pearlite nose. However, the steel is still transforming after that 1/2 second. Thats why you don't take the steel out of the quench after only 1/2 a second. Also, agitating the steel helps ensure there is no vapor jacket around it.
It's a heat transfer (thermal jacket & viscosity are 2 key factors) issue, not HQK vs P50.
http://www.engineeringtoolbox.com/conductive-heat-transfer-d_428.html
http://heatbath.com/heat-treating-products-2/oil-based-quenchants/
http://www.engineeringtoolbox.com/dynamic-absolute-kinematic-viscosity-d_412.html
http://www.engineeringtoolbox.com/viscosity-converter-d_413.html
For thick W2: Rough surface + higher viscosity oil(than brine/water) = persistent thermal jacket lowered dT = hit pearlite.
I have been down the rabbit hole before with your technobabble and if you think you can get full hardness with canola oil on W-2 more power to you but I wont buy one of your knives, LOL.
It seems like you just want to argue.
I'll leave you this to read:
http://www.scielo.br/scielo.php?script=sci_arttext&pid=S1516-14392005000400018
