I've said everything I needed to say, and probably a bit more. Please, keep talking though.It's clear what you're here to talk about, and that is cool too. I think the point has been made abundantly clear though.
Sam :thumbup:
Okay, Sam, where did you find that photo? I've never seen that Lile before. :thumbup:
Loving these pre-First Blood knives. Two from Mike Leach from the 70s. Wonder where he got the idea to use a crutchtip?
I say baton away. What do you think.
I'm not a batonner, but I have batonned before and understand the concept. In a survival situation, I would have complete confidence batoning with my Running River knife shown a few pages back. That blade ain't goin' nowhere. I'd be more concerned with the well-being of the log.![]()
I am just becoming aware that there are some misgivings about batoning, is there? In my mind, with the super strong construction of today's HH knives like the ones we see one this thread, there would be no problem.
I say baton away. What do you think. If you are a batonner, have you had problems? If you are a maker, do you prefer people don't baton on your knives?
What do you think?
Maybe this has already been covered and I missed it.
Wait a minute. When I discussed the academics of jointed steel vs, one piece strength, I was told there was no difference.
Now, you're worried about catastrophic damage from batoning tiny sticks?
Or is it because of the sushi-chef edge you put on your hard-use survival blades?
I batoned a pallet full of Duraflame-type logs with a $20 Cold Steel machete and a 2.5 lb hammer with minimal damage.
I can't imagine being afraid to use it on real wood sticks the size of a cucumber.
Aside from a few skeptics dubious about the inherent usefulness of batoning, I've rarely heard these days anyone with specific misgivings about it, aside from me that is...
My personal misgivings about batoning are entirely based on two five minute experiment with one knife: I needed to go no further...
The knife in question was a Stainless 440B Randall Model 12 with 14 grind, which had probably the best knife edge I have ever owned aside the Lile Mission and my Oryx Raider II... After thousands of chops in a variety of hard dried woods, the Model 12 showed absolutely no visible damage except for slow dulling, this on a less than 15 per side edge angle on a thin 0.020" base. (Most survival knives I have chopped with showed quite obvious destructive damage, usually in less than ten hits, when anywhere under 20 per side: Micro-rolls or micro-chips... This despite much thicker edge bases... These included, notably, a $2K RJ Martin Raven, A Neeley SA9, ACK Sly II, at least one Martin, and even one of my two Liles -this last one maybe performing poorly due to a heavy full height re-grind, I can't say-...
So I tried this "king of knives", the Model 12 I mean, sharpened -cold- by hand for two years, to do some mild splitting of small 2" diameter sticks: In five minutes of splitting these tiny sticks, the entire edge was micro-rolled (hard to see and only detectable by nail rubbing), having suffered more damage in 30 baton hits than in about 1500 hard chops... In disbelief, I repeated the test later, with great care, to the exact same result...
After this, I did the same as does the spell-check: I dropped "batoning" from my vocabulary... Maybe with extra-blunt 20 per side edges this phenomenon disappears, but likely subtle micro-rolling is simply not noticed by most users, who just get by with rapid geometry height loss, since a rolled edge an cut very well for a long time, and the effect is mostly that you lose bevel height faster on re-sharpening...
Another, even bigger, reason that batoning is a bad idea is that it is by far the use most associated with catastrophic breakage, this because the blade is "trapped" and not free to vibrate "naturally": No matter what anyone says, vibration fatigue is essentially unpredictable, especially in low temperatures (as if that wasn't bad enough!)... Batoning is OK for backyard use, but has nothing to do with rational "Survival" use, unless maybe the situation is imminent death from exposure, when physically wet and surrounded by wet wood, so yes there is still that one very narrow scenario... Even then, one should not "train" for this with the actual knife, since every hit makes a subsequent failure more and more likely, unless you claim to know what is going on at the microscopic level inside the steel...
Gaston
Did you ruin the edge on that machete by sharpening it ridiculously thin before you did this task? Because that might explain why you weren't successful in damaging it beyond belief. Just thought.
I've seen actual 10 degree per side edges put on by REK at my request, huge true and perfect V-edge bevels applied with the Wicked-Edge, and this still held up perfectly to hard chopping with Aus-6 made in Japan (but on a smaller 6" blade, so less energy).
The Randall Model 12 that micro-rolled while batoning was at least 30-40% more open: So around 13-14 degrees per side, probably more counting the inevitable imperfect "swelling" of hand-sharpening: If you call that "Sushi-chef", then we simply don't have the same conception of sharpness...
There are two obvious ways to avoid micro-rolling while batoning: Not noticing it, or calling 20 degrees per side "sharp".
A third way is obviously behind the huge popularity of convex edges: It is very possible a nicely polished convex edge solves the "micro-rolling" problem completely by being duller near the apex. I call convex edges "duller" and go on from there...: The reason I do this is that, inevitably, I will gradually "convex" a true V-edge after a lot of crude sharpening in the field, so I'd rather not start with what I will eventually end up with...
If batoning gets me to a convex edge faster because of micro-rolling, then to me that is a bad thing. If you start with a convex edge, or the usual slightly "swelled" hand-applied edge, then you might not get any micro-rolling.
I do check very carefully for wire edges, so I do know when micro-rolling appears: It is not set up by a previous flaw I induced by sharpening... Interestingly, the micro-rolling was more pronounced near the tip of the Model 12, even if the splitting was started near the middle of the blade: This suggest the asymmetry in loads on the apex gets worse after the wood has split, which is quite counter-intuitive...
I really rather doubt I have the only steel in the world that behaves like this...
Gaston
Not sure if it's pre-Rambo, but apparently, this is the first Chris Reeve One-Piece knife.
