you can get all the equipment for it in under $500 - single stage press (for resizing the spent shell back to spec, de-priming, priming, seating the bullet, crimping), dies, caliper, scale, manual shell trimmer, etc.
i run lee precision gear although dillon precision is considered the top level stuff (they even have the no b.s. warranty like esee). dillon is for high volume shooters due to their progressive press (1,000 rounds in an hour anyone?). i equate lee gear to the becker/ka-bar knives.
i have lee gear although i did invest in a $425 giraud powered case trimmer. there are cheaper options like $30 shell trimmers that uses a regular hand drill/press but requires more steps for you. manually trimming cases was the only part of reloading that almost made me quit though and forced me to buy a giraud. i was 29 at the time i started reloading but after trimming 100 cases manually it made my hands feel like i was 80 yrs old!
reloading is a lot of fun as long as you find extreme attention to detail enjoyable. just checked my manual - 7mm 08 rounds are in the 50,000 psi range and higher - and your face is only inches away from it! for comparison, a typical .45 acp load is 20,000 psi and it's an arm's length from your face.
did i mention attention to detail?
if you cut yourself wrapping an izula you better not start reloading
