DSCF5413 by Ethan Koukides, on Flickr
DSCF5400 by Ethan Koukides, on Flickr
DSCF5391 by Ethan Koukides, on FlickrLawrence - sorry I did not respond to you on this earlier - thank you for the comment. I will definitely include a couple blocks for black color in my next lot to K&G - probably early Jan. My test blocks are actually drying very very nicely in my box at 90 degrees (F). Went from ambient 10% or to, down to 0.5% in about a week. Burled and Spalted wood seem to dry that last bit in a flash when put under the right conditions....I have purchased some Maple burl scales that were stabilized & dyed with black and it came out excellent! You could see the red, Brown to white specks in the burl with a Milky Way type swirl pattern as it darkened. The knife sold to the first person to pick it up! Of course I lost the pics of it.,,I will do it myself when I send in a batch to K&G. Thy it on a few blocks!
Don’t rush the drying too much. That can cause cracks.Lawrence - sorry I did not respond to you on this earlier - thank you for the comment. I will definitely include a couple blocks for black color in my next lot to K&G - probably early Jan. My test blocks are actually drying very very nicely in my box at 90 degrees (F). Went from ambient 10% or to, down to 0.5% in about a week. Burled and Spalted wood seem to dry that last bit in a flash when put under the right conditions....
That’s why I mentioned “test blocks” .. as in blocks put into the drying box to test whether they will split or crack. Actually, pretty much across the board, varying from dense rosewoods to sparled wood and burl, once below 12-15% moisture, I have had almost zero problem with splitting of wood in the drying box. Curiously, I have had problems only with locally harvested black walnut, and even then only pieces that had some kind of knot in them. These most recent cherry burls appear to be pretty stable in drying, as are the sparled maple I got from WEO. Beginners luck maybe, but I am pretty cautious to be sure about their moisture content before I expose them to higher temps...Don’t rush the drying too much. That can cause cracks.
Knots can make twisting/drying more likely to crack. There are so many variables with different woods, seasonal differences etc. that’s why I set pieces to dry 1” per year...That’s why I mentioned “test blocks” .. as in blocks put into the drying box to test whether they will split or crack. Actually, pretty much across the board, varying from dense rosewoods to sparled wood and burl, once below 12-15% moisture, I have had almost zero problem with splitting of wood in the drying box. Curiously, I have had problems only with locally harvested black walnut, and even then only pieces that had some kind of knot in them. These most recent cherry burls appear to be pretty stable in drying, as are the sparled maple I got from WEO. Beginners luck maybe, but I am pretty cautious to be sure about their moisture content before I expose them to higher temps...
No reason. I hadn't thought to thin it except for down at the bottom where the fold is. These are not very wide, so have felt I needed the full thickness at the handle. I hadn't thought to shave it down on these down by the blade. That would make it more balanced as these are smaller more delicate looking knives.Ashwinearl, why such a thick weld on those sheaths?
The wife ordered me one for Christmas, she was a little bummed when she found out it takes about 6 weeks to deliver. I'm looking forward to warping all kinds of knives.Got a great Christmas present. A new heat treating oven. Evenheat recommends running the first firing empty. Going to do that tonight. Looking forward to working with some stainless steels.
