Pin in bolster is visible ?
In my shop this days , easy .........Natlek, how do you loose a scale?
Pins done , they are 3mm before now are 4mm .That scale will go nowhere .........
After file work .........
My tool for pins , one big roller from spherical roller bearing jammed in tube .........
This is the first gyuto I ever made. I finished it a few weeks ago but only just got around to photographing it. It's a 216mm gyuto ground from 0.084" (2.1mm) AEB-L with a subtle distal taper and a faceted convex grind. The base of the visible blade in the choil photo is 0.065" thick at that point. I finished the blade longitudinally on a very fine scotch brite belt to give a satin finish. This is my favorite finish for a knife that I intend to use a lot because it hides scratches and is very easy to touch up. I made a 135mm long wa handle out of stabilized buckeye burl with an ebony ferrule, finished with tru oil.
