To celebrate the end of a project at work that I actually enjoyed I made everyone on the team this bottle opener - utterly impractical, unergonomic, but heavy and shiny.
I have that same guide, expensive bit of kit, but well built! (mine did come where the surfaces are a few thou off, but there's just enough movement in the pins that I can tap the lower side up and it comes into alignment perfectly (if that makes sense)Two new toys for the shop.....
I wanted to get a glass platen for awhile, finally I set it up. I milled a little ledge and tig welded it to my original platen. The glass I bought was longer than expected.... I scored it and broke it to fit. It was not quite right. I was able to grind it perfectly on my 2x72 with ceramic belts. I was surprised how easy it was to grind the glass...? :0
Also, I splurged on a bevel guide.
It was more than I wanted to spend, but WOW, am I impressed.... Very high quality. It glides tight and smooth on the pins. All the work that goes into it, I couldn't of made it better.
Hope these 2 help my knives look a little better!
I'm not at work where my gauges are, and I didn't indicate them? But didn't notice any difference.... But I'll look a little closerI have that same guide, expensive bit of kit, but well built! (mine did come where the surfaces are a few thou off, but there's just enough movement in the pins that I can tap the lower side up and it comes into alignment perfectly (if that makes sense)
Can you show what bit you use to scratch your name and text. Do you fo that prevor post HT?Sheffield inspired Real Lambfoot Knife
8670 carbon steel, SS threaded bolsters, liners, shield, pins, bronze washers, stabilized burl over black G10 liners. Manual scratch engraving+electro etch with Gravograph pantograph. paste wax finish on scales.
Hi, I am using a Gravograph (like Hermes) pantograph engraver. I use it in manual mode (no motor running) with a Diamond Drag Bit, similar to this (https://www.gravostoreusa.com/eng/product/33954).Can you show what bit you use to scratch your name and text. Do you fo that prevor post HT?
