What's going on in your shop? Show us whats going on, and talk a bit about your work!
Don't make a sheath when you are upset, it turns out lefthanded.
These two sheats come out of the same piece of leather. The darker one got a coat of neatsfoot oil and a few weeks of sunlight. I like the rich darker colour.
This is how I tan my oiled leather sheats in sunlight.
I hate it when that happens.
I installed a Chinese diesel heater in the knife shop so now it will be -5 instead of -10 degrees
I was just today considering that same type heater. The LP does a good job with the temps but leave too much moisture in there. Let us know how it works out, please.
I hope that you are well and its nothing too serious that caused the upset.
You have a great sheath there and it looks like a natural aged patina, its very nice.
Some lefty will be delighted with that as a Christmas present!
I work in a partially insulated garage shop. This bad boy has probably been one of the best purchases I've made for it. Keeps ME warm, rather than trying to warm up the shop.
I have one of those and it keeps giving me problems. Mostly giving an alarm. I think it's the shop dust. Does yours alarm out at times?
Only when I try to put it on an uneven surface. As long as I have it on the concrete floor, I haven't had any issues with the alarm.
I used a Chinese diesel heater last winter in the knife shop. The shop is small and not insulated and I am to cheap to run the heater if I am not working. I start the heater an hour or two before I want to start working on knives and on a 15 degree morning the temperature would be tempered to 30-40 degrees which works for me.
For 100 dollars I would say it is probably the coolest thing I have bought, just love having reliable and portable heat source. I actually just bought another one as my original one I installed in more of a permanent situation with fuel tank outside of building.
They do require a 12 volt power supply with enough power to run glow plug and fan on startup. I use a 12 volt RV battery hooked up to a 1 amp trickle charge.
They are overrated in heat output. The 5kw of two years ago are now all 8kw but with how the settings work they are probaly closer to 4kw of output. On my unit the 2 hottest settings barely create anymore heat than setting 4 but use substantial more fuel and burn much dirtier.
In the old grinding room, which was a small and unheated shed right off the open smithy, I would set a propane torpedo heater outside in the smithy and point it toward the open door. It would warm the place up a lot in about 20-30 minutes. I would back it down and grind away. When forging in the smithy, I would place it about 8 feet away from me and it would keep me toasty while I worked on the cold days below 35°.
They come in kerosene, diesel, propane, and multi-fuel types. I like the propane ones because they are safer, don't have any smell, and can turn on/off instantly. They are very affordable new at placed like HF, and often found for low prices at pawn shops and yard sales.
In the new shop there are four "areas". One is the 20X13 clean shop, which as the name implies, is not for machining and grinding or hot work. The main area is the "machine and hot shop" and has workbenches, machine tools, and welding equipment. The stairwell going upstairs in it. The 10X12 grinding room is enclosed by half-walls with glass windows above them and has its own in and out air supplies as well as dust collection and air filtering. The 20X40 upstairs is open and has the big building vent fan.
I used two propane catalytic heaters while building things. I have only used them to warm the hot shop up a few times since construction. Since the machine shop work areas are ventilated to the second floor, there is no worry about O2, CO2, and CO levels, but I have detectors anyway. The torpedo heater was overkill in the machine shop except one very cold period of 20° weather.
The clean shop portion of the new shop has an AC/heat mini-split system that keeps it between 65° and 70° 24-7. I insulated that portion of the shop very well and it only sips electricity. I doubt it averages $10 a month in electricity. I highly recommend them for enclosed and insulated shops.
Your thumb was too long, anyhow.
That's standard practice for me. I do about 35 blades at a time and when I get around to the 35th I've ground enough of my finger down to hit the important stuff like arteries and nerves. By the time it all grows back I'm starting on the next 35 again, it's a never ending groundhog day for my poor thumb! 😵‍💫 😁
Also doing some safer shield pinning🙂
Eric
