- Apr 7, 2002
I don't have a problem with 440C, my issue is mostly price point. A $20 production folder in 440C is wonderful, but at $80 it's not great.
Because they don't have a clue.Why do people knock 440C so readily???
Proper HT is a must. Why would you want any steel, 440C, 420 or whatever improperly HTed?
Unfortunately, the way some posters portray things, there is some magic HT that can make 440C or any other "good old" steel perform better or equal(for unspecified tasks) with the modern alloys for the same tasks.
Amateur knife enthusiasts aside, this is simply discounting all the science that goes into metallurgy, steel research and development.
Disregarding all the new alloys as marketing gimmicks and false promises is wrong, and has no basis at all. Knife makers, tool makers, factories use those alloys and it does make difference for them. They last longer, are lighter, or allow for shallower angles, consuming less energy during cutting, etc.
I understand where some of it is coming from. Put the same 40 deg. inclusive edge on all of your knives and then it will be quite difficult for some of the cutting jobs to see the advantage of the new alloys.
However, a knife is a tool, which has one function, to cut, and easier it cuts, and longer it stays sharper, higher its performance and value as a tool. It is very obvious from physics and every day experience, thin edges cut better than thick ones. Theoretically the goal is to have the edge as thin as possible that can stay sharp and not break for a given work, not to have an edge so thick that it barely cuts. That's common sense and very simple logic.
The main obstacle having thinner edges is the steel properties, there are no alloys today allowing for let's say 3deg. per side edges for hard use knives, or even medium cutters. But I do have bunch of high performance light or even medium cutters between 5-10 per side. And they outcut thick edged knives many to one. 440C even with best HT, at that angle will not last 15 minutes. Yes, it will last longer with 20 per side edge, but that means loss of cutting ability, plain and simple, there is no other way around. In other words, the user has to exert that much more force and energy.
It does make a difference, whenever I have to cut an hour or longer I really feel the difference in fatigue and overall speed or work process, plus sharpening and maintenance. Older, softer steels do need more time to keep them sharp and contrary to the popular belief they're not very easy to sharpen, while I could restore sharp edge on high hardness, thin edge with few strokes on the smooth steel, softer edge required major sharpening.
If you view a knife as a workout tool, may be that works, but otherwise, thin edges cut better. The only reason we are forced to have thick edges is the inability of the alloy to perform adequately with a thin one.
So, in the end, today, other than a budget(even if that), there is absolutely no performance related reason to buy 440C knife. Well, if you like the knife design, or have other reasons, fine. There is no shame in thatBut touting 440C steel as high performance alloy today... It's rather disservice to knife community.
If I want a knife optimized for cutting and long edge holding, there's bunch of stainless steels that will perform a lot better than 440C.
Higher corrosion resistance comes from other, modern alloys including Ti and Co alloys.
If I want hard use knife then there's another class of new alloys optimized for that.
same reason some people don't like 30-06.
Same reason some people don't like 30-06.
I would take 19C27, better chemistry and still 'cheap'.
Well, nobody specified in what aspect 440C is superior to what, when or how. In every aspect of knife steel performance there are better choices. That's my point, plus my opinion that there is no need to cling to 50 yr. old alloys. Besides, users can be educated.You seem to dismiss it as wholly inferior in every aspect, simply because there are better steels available. I simply submit that those better steels are not always the better choice in all situations. Sometimes the better choice is to go with what works well at a certain price point.
I doubt the number is 99%, at least amongst the ones who care about the steel. Second, ignorant users are no reason to dismiss science and progress.and 99% of the users will never push any of them to their limits in day-to-day usage,
When one needs a knife that looks cool but also has high performance (I do care), then there's the choice, mediocre steel, or the one that performs few times better.Steel choice should be secondary; if you like the knife, buy it, and use it and quit worrying about what all those little atoms and elements are doing.
But I think a quality design overrides all of that. I'd rather have a design I like in 440C than a design I don't care for in any steel. I carry my BM 527 more than any other knife even though the steel is "inferior" to S30V etc.
