Why doesn't anyone make knives that compete with Cold Steel?
Hmm this post is suspect, the first paragraph mainly. You say that a spyderco rep quoted a lock rating of 1000lbs.
I find that suspect since Sal Glesser himself has stated many times that they never have and never will release lock stats to the public. Do you by chance have the name of this "rep" that told you this? I'm sure he'd like to know about it.
@ Pete, I should just say that the only reason I was surprised by the results of my "test" is that I had been assured by a Spyderco rep that their lock was one of the strongest in the business, and that it could support over a thousand pounds of force applied directly to the pivot without failing. I don't regularly abuse my knives (that one seemed like a good opportunity because I have a sprint run Manix 2, and one I broke never gets carried), or use them in fashions other than what one would expect a knife to be able to handle.
What I think is worth remarking about my success breaking my Manix 2 is that it is often marketed as an extremely hard use lock that will never fail, and I had it direct from their sales guy in their factory outlet that it wouldn't fail, even under heavy abuse. I've done the same before to a BM 530, knowing in advance that such a light knife would break somehow, but it was the handle that broke, not the lock. That from a 2 oz knife. I don't think it's necessarily a strike against the Manix 2 that it did fail under what is admittedly abuse. I DO think it is a strike against Spyderco to tell a potential customer that the Ball Bearing Lock is in any way as strong as the Triad lock and will hold up under heavy abuse, when in fact it won't. And it's not even like the lock failed. It straight up broke.
Should that be taken as a knock against Spyderco knives in general? No. I love Spyderco, and don't hesitate to recommend their knives. But I asked specifically about the failures in spine whack tests, and was told specifically that they had fixed that issue, and that they had tested the new ball bearing lock by clamping the blade and handle and suspending weight in the middle above the pivot to find out how much it took before it broke. The rep said specifically that they put 1000 pounds of weight on before it broke, and even then, the handle broke, and the lock never failed. And that's not from some knife store guy. That's from a rep who works in their factory outlet in Golden and said he regularly works in the factory itself. I find it hard to believe that 10 whacks with a wooden baton could literally break the ball bearing loose from the lock, if that story were true. I was told that if I wanted a hard-use knife whose lock would "never fail," I should purchase the Manix 2. I bought it at factory outlet prices too, on the strength of that story. That's about 30 dollars more than it goes for on the secondary market.
And I used the knife WITHOUT abusing it for a year, and I still think it's a great knife. But the fact that it DID fail under circumstances considerably less strenuous than I was led to believe by a company employee that it would survive, strikes me as false advertising, and I think others, who thought as I do that the Manix 2 lock is just as strong as it's competitors from Cold Steel and Benchmade, ought to know that's just not true.
-edit- I should also say that the only reason I did this in the first place is that I was confident, based on the assurances I had from the company, that it would hold up very well against abuse, and I could put to rest the claims that it's not a solid lock. I went into that as a firm believer in the Ball Bearing lock, otherwise I'd never have attempted it. I don't really like breaking my knives, especially when I paid nearly $100 for the thing.
Comparing a Cold Steel (or any knife that claims to be "hard use") to a Spyderco is like comparing a Jeep with a Porsche. I don't understand why this conversation is even taking place.
Well, then why are you invovled with it?
No, I don't recall the guy's name. It was a relatively generic American name (John, or something, not hardly memorable). But I would recognize his face if I saw him again, since I talked to him for about an hour. He worked in their factory outlet store in Golden, and said he usually works in the factory. It was about a year ago. If you're going to accuse me of lying, come here to Colorado and do it to my face.
Now, I should remark that this isn't an "official spec release" or whatever nonsense you want to call it. Nor is it an official account of what they guarantee the lock being capable of. It was, however, as I have stated repeatedly, an account of a test run at the factory by a factory employee in the factory outlet store to a potential customer, who bought the knife based on that account. It clearly isn't an official press release or anything like that, and as such, your comment is utterly irrelevant.
No it's not a Manix 2, it's a Spyderco folder though and my point is Spyderco makes thick and thinner pointed knives, because sometimes you want a choice.
You might try reading a few of the posts before posting a photo that was purported to debunk mine!
I'm a big Cold Steel fan, and I especially like Demko's designs, work, test videos and explanations.
Ahh, so it was just pulled out of thin air. Lulz.
You say in your own words that "he assured me that the lock would support over 1000 pounds." Either you, or him pulled that out of thin air. I think we can leave it at that, since we know that Spyderco does not release lock data to the public.
When I see people that are wrong, I correct them. Not because I expect them to learn anything (some people are lost causes), but to point out the misinformation to any unsuspecting newbies who might believe the wrong thing simply because they read it.
I wasn't trying to "debunk" anything. I was just showing Spyderco has folders with thick tips. If I want a Spyderco with a thick tip I can choose a different model, than the Manix 2. If I want a sharper point, I can choose the Manix 2. A knife is used most often for the cutting ability, anyway not just brute force.
This thread is about Cold Steel? I thought it was about Spydercos and their weak tips.:confused:
I clicked on by mistake and as I read more and more, it did seem that this post was about weak tipped Spyderco's!:eek:;) But after reading the original post I determined it was indeed about CS.:thumbup::)
Yes, evidently the Spyderco employee made up the story to gull a prospective customer into buying. That's precisely why I was offended by the lock breaking. I had thought I would be able to prove it was one of the strongest locks out there.
If you are so much of a doubter that you want to verify, why don't you check my past history of posts on here relating to Spyderco and the Manix 2. I've been a fan of the Manix 2 and have touted it as being a strong lock based on that exact story many times in the past.
In fact, I'll save you some time. The guy's name was Barry:
http://www.bladeforums.com/forums/s...Spyderco-virginity-today-)?highlight=spyderco
I really don't care either way. I'm happy with my Manix knives. They have served me well for a long time. I do find it strange that you are so concerned about proving yourself right.
Hahaha you are too much. I am going to assume your arguments stem from irrational thoughts in your head and not real life experience??
I'd call this a pretty good example of a really immature mind at work...It's in response to my questioning of the utility of the Manix 2's too thin tip! My favorite however, is the youngster a few pages back that simply stated that he had reported my post for trolling! So I'll bail on this thread as it's obvious that the middle schoolers are done with the homework....Au revoir Les enfants...:)
With Glocks it's not as bad as it used to be but I remember when I went through the academy the salty old guys would gaurantee that any agency that issued them would have ND's (didn't come true) called them combat Tupperware. Then there's the whole 40 KB issue (again I've never talked to anyone who had first hand knowledge of one....was always a friend of a friend. At the end of the day I think it was because they would do these super intense torture videos to demonstrate the reliability and toughness of the guns (like dropping them out of helicopters while frozen in a block of ice then run them over with a big truck and burry them in mud and then shoot them). At the same time they were not traditional designs (striker fired) and were made of cheaper materials (polymer) and were themselves cheaper then all their competitors all the while claiming to be better then all their competitors. I think all that rubbed people the wrong way. At the end of the day though if you just look at the gun it's a well made reliable firearm that costs maybe half of what a Sig or HK does. They're not my cup of tea but they're a quality item and have performed as advertised when I've shot them and they're commonly found along with other tier one companies firearms all the way from patrol officers holsters to specialized military units throughout the world. If you really want to open a can of worms start a 1911 vs Glock conversation....or even better an M-16 vs AK-47 conversation....and step out of the way.
the descent into name calling identifies you as pure internet tough guy, we all know what thats worth, don't we?
Do you even own a Manix 2?
As an owner and user of a CS Recon 1, Manix 2, BM Grip and Torrent I can say I would pretty much trust my life with each of these. They are all great in their own right, and all capable of a scary edge.
This discussion is like Ford vs Chevy vs Dodge Trucks. They all work well, just have different characteristics.
Frankly if you want to talk value and durability get a Buck 110 and it will perform just as well as any Spyderco or Benchmade at 99.5 percent of tasks....
But please continue to debate this topic with unnecessary fervor and bias...it's entertaining... Or people could stop basing their beliefs on endless hours of youtube videos commonly created by idiots with less knowledge and experience than the 'manufacturer fanboys' that watch them and troll forums.
"Thanks for winning it for me, the descent into name calling identifies you as pure internet tough guy, we all know what thats worth, don't we?"
I suppose you're an internet tough guy, as well? Ya' know, for calling us middle schoolers. :rolleyes:
Cool thread.
I am disappointed in the tip strength of my UKPK. I tried stabbing my car hood and it just snapped right off. The lock isn't very strong either. It closed on my fingers. Damn knife.
Oh well. Maybe I will just start using it TO CUT THINGS.
Maybe they're popular because some people want to carry a large cheap folder where it's illegal to have over 3.5" or 4"+ blades?
Who wants to make some cops day by having to hand over a $200 knife?
