I know you dont know who I am, or have any idea of my background ...
Thomas, this seems to be a stopping point to you so I will clearify it in detail. It is fundamental that the arguement is never evaluated on the merits of the speaker. I don't respond to what you write, I respond to what is written.
The only time the speaker would present himself as the arguement would be when the audience is so ignorant that they are incapable of understanding the details of the arguement. I am sure you would never suggest that any readers of this forum would be so characterized.
If you havent been around volume manufacturing this is difficult to recognize or even accept ...
Thomas, I am well aware of the influence of compromise. It is always the case that money and time restrict academic research. There is always better equipment you could buy, more expensive materials to work with, more support staff, etc. . It is also often the case that someone else will not be so constrained and that is life . You produce the best you can with what you have available. Knowledge, imagination and desire will go a long way.
But when you ask the manager of the restaraunt the question and not the cook you get the answer given.
Generally they know the details, but if they don't then they will ask the cook. The above details on heat treating I cited were not from the person who did the heat treating, it was from a representative of the company. They just asked for the information requested. You really think that Thomas never checks with others at Kershaw for details on questions he is asked?
For example, a razor blade is typically used for scraping off inspection stickers, grunge jobs and general contracting utility blades for jobs like taking out old caulking from an old window, cutting up linoleum flooring, carpeting, and various other tough 'beater' jobs on a daily basis besides ...
The steel isn't designed to do that STR. The razor blades you are talking about are not made out of 13C26 because it would be an absurd steel for that application. It would be like making a fillet knife out of S7. It you wanted to use a sandvik steel for that then you would use the higher carbon steel because what you are describing is highly dependent on wear resistance.
Are you referring to Marquench?
Yes, these are all air hardening steels (sandvik stainless) so you don't need to fully quench them to room temperature to avoid the diffusion reactions. However you want to cool them down to the Ms point quickly because when they are very hot they will precipitate chromium carbide along the grain boundries and this will deplete the chromium and carbon in the steel so it will reduce the hardness and the corrosion resistance and weakens the grain boundries which will make it more prone to edge damage and as well less efficient in sharpening.
This by the way isn't something which is inherent for those steels, it happens to all stainless (and similar alloyed tool steels). It will just be noticed more in these steels because of how they are typically used which is in very acute profiles at a high polish. If you have obtuse / coarse edges then you tend to see mainly the wear resistance so if the steel has lots of carbides then you will be fine regardless. Plus, such steels are inherently brittle anyway so no one really expects much of them in that regard.
These blades cut like razors and for all I know are made out of a Sandvik style or class of steel.
They are generally simple carbon steels with a very basic heat treatment. No one expect much of them besides the fact that they are very sharp initially. I have worked with, and literally seen thousands of such blades worn dull, broken and quickly replaced. They are $0.25 or so and almost no one resharpens them.
Recently higher performance ones are available, some are HSS and are much more suitable for the type of work you noted because the wear resistance is many times greater and the individuals don't want ultimate sharpness they want to work for a long time with a decently sharp edge.
-Cliff
