On the subject of the steel being a beater steel, I'm not sure what the issue is here.
It is the same issue which already lead AEB-L to be wrote off as a low end cutlery steel because it had been reduced to such. While Verhoeven and Landes have done much work to illustrate the potential of low carbide steels for cutlery as focused on cutting performance, Devin really brought this steel into the public in a positive manner as a high end material as the public isn't as aware of the research done by Landes and Verhoeven.
.... it is doubtful the heat treat methods incorporated into it then were the same as Kershaw is currently using today.
This isn't actually that relevant and those steels have actually been used in cutlery for a very long time. The Sandvik steels have a low wear resistance as their carbide volume is really low, heat treatment doesn't actually effect this significantly outside of extremes. What happened was quite simply that people looked at the low carbon value of the Sandvik steels and concluded they were "beaters". When they were compared to the high carbide steels for cutting abrasive media they were indeed found to be behind in performance and thus AEB-L was basically equated to 440B. This was done by some very well respected members of the knife community such as Engnath and unfortunately when one vocal maker/manufacturer states such an opinion it tends to become law very quickly because of the faith based perspective which is common in cutlery.
Now, quite frankly, could any custom maker sell knives out of AUS-6 as high performance blades - maybe, if you were someone of Cashen's status, but for most makers it would be a real problem. It actually is though, it is just behind AEB-L in edge stability, the hardness is just a point or two lower and the carbide volume and type similar. AUS-6 actually is on the same tie line as 440C and that means it has the same maximum hardness. But how are they perceived (radically different) and why are they perceived that way. Because manufacturers wanted a very cheap steel to use in cheap knives and the steel unfortunately became known as a cheap material which was "low end".
Now to make it clear, the sandivk steels are very tough, much more than the high carbon stainless, but if you use obtuse edge profiles you don't need a high toughness in the steels. So it isn't that the sandvik steels won't do well as beaters it is simply that the other steels will do better because you have created a biased comparison because your edge configuration removes the weakness of the high carbide steels and the strength of the sandvik steels. It is a really lopsided comparison which is what destroyed the reputation of those steels already on the NA market and favored the current promotion of high carbide stainless as "superior" because they actually are superior in really obtuse edge configurations.
What would you suggest for steel that can be manufactured at a similar price but give better performance?
In thicker edge profiles you would use a higher carbide steel to take advantage of the inherent edge stability (and toughness) of the cross section. Sandvik makes 19C27 for that type of edge. However the most logical steel to use would be CPM154 because you can take advantage of Crucible promotion of the steel and the wide acceptance of "quality" of those steels whereas with 19C27 you basically have to do all that promotion yourself.
And can we come to an agreement that even if not being used properly 13C26 is an improvement over 440-A?
In general this is like asking is a fillet knife an improvement over a paring knife. There is critical information being left out of that question which is what are the critical aspects of performance. 440A has a much higher carbide volume than 13C26 which gives it a large advantage in wear resistance but in cutlery it is limited by the fact it is usually really underhardened. It actually tops out with oil/cold at about 59 HRC, but is usually much softer so you end up with chunky carbides in an edge which tends to easily dent, roll and is aggravating to sharpen to a high sharpness unless you have jedi level skills. Pretty much another beater steel, but again not really the fault of the steel.
They may have to take the leap of faith that you suggest.
Sure, but I don't force it on anyone and that is a critical point. I'll explain my perspective right down to basics if you want in as much detail as you want. I won't force you to accept anything I say simply because I say it and I will give you the references so you can read them yourself. I have even sent many knives out to people so they could check what I was saying and evaluate the principles for themselves. I was doing passarounds before there was a pass around forum on bladeforums.
Unfortunately without knowing any of the educational or experiential background and expertise of those writing, including you, how is anyone supposed to know whose opinion or information is accurate and/or valid?
You get educated, people selling hype thrive on ignorance, people who seek the truth do not. Go over to Cashen's forum and find some point he has made and say something like :
"Cashen, you have stated XXX, that makes no sense to me and further it even seems absurd if you consider XXX. Do you have any data to support your viewpoint and independent published work which predicts that behavior from a fundamental level."
His answer will be basically :
"Yes, I have done XXX and you can read about the underlying materials science here XXX."
What he won't do is go on a rant about how great he is, why you should listed to him, how long he has been in the business, how much praise he receives from his customers, he has no need to justify what he says to you some pinhead newb poster, and encourage others to do the same to attempt to prevent such challenges. He knows why he does what he does and it is supported by facts and logic and he will tell you these facts and logic if you ask him.
Now if you don't have the time or inclination to get educated then there are still many things you can do. Immediately you disregard commentary from salesmen, you disregard anyone who has not shown the ability to be independent (they just repeat whatever is commonly accepted), you disregard people who won't explain their viewpoint, you disregard people who attack speakers and not the argument, and you disregard people who are inconsistent (apply one set of criteria to products they promote but another set to products they attack). If you do all of this you will find that very little contradiction remains.
I rarely if ever have seen him actually take his comments to a personal level.
People have characteristics, characteristics determine actions, it makes as much sense to get angry at insecure people for lashing out as it does to complain that rain makes you wet. If you go out side in the rain then wear a coat, if you point out hype and misinformation, especially by someone selling something, then prepare for a character backlash. No it isn't ideal behavior and no you should not have to tolerate it but it is reality, especially if you are contending a well entrenched falsehood. The most you can do is represent the type of behavior you would wish to be reflected at yourself. If it really bothers you and you have difficulty in separating the criticism from yourself then create an identity and post under that which you can defend via a third person argument.
-Cliff
