BluntCut MetalWorks
- Apr 28, 2012
... Ecc ...
Dude, you've got to cut down on all the jibberish. Real world heat treating should be followed by practical use and experiments.
Hoss
I would like to see videos of the 66 RC W2 chopper, with a rockwell test in the same scene.
Hoss
Sorry OP - for my OT
^ this :thumbup:
One thing I've learned is the heat treats specified by the steel makers aren't optimized for our application. Also, there is a lot going on that you can't measure with a hardness test. The only real way to optimize a heat treat and validate your work is practical use and experiments.
During development it's helpful to minimize variables and maximize the "signal to noise ratio" by tightly controlling the geometry of test pieces (no guessing at edge angles, 2 degrees makes a big difference in the outcome), standardizing on cut tests, the use of cut test standards, and doing things like grind edges wet to remove heat as a potential variable etc. When you boil it down and control every variable you can dial in a heat treat. But beyond a certain point it requires real work to do this, not theory. At the end of the day you might have something that is different than other people do it.* You might not even be able to explain why all of it works. But ultimately it boils down to real work and real R&D. Practical use and experiments. Otherwise, if you haven't done your homework your opinion is just an opinion :thumbup:
*edit to add: My copy of Tool Steels 5th edition is an important addition to the 4th edition that many of us have. The fact that so much information changed in recent years shows that a lot of this stuff is still not figured out. If the PHD metallurgists in industry are still figuring it out, there is still a lot out there to figure out. It isn't a mature science yet and you can do something for your application that isn't in the literature.
Please allow me to hand-waving about matrix strength using informal emperical data. HRC is useful in a sense of repeatable average composite indicator for compressive strength - good enough for this discussion (I think).
Let's look at some steels.
Ht for max HRC. Where HRC is a composite indicator of strength (Matrix + Particle strengthening + ignoring grain angle alignment/dislocation)
1084 (less than 0.5 carbide volume %) - 67rc
W2 (~3 cv%) - 68rc
AEB-L (~ 2.6 cv%) - 65rc
3V (~ 2.7 cv%) - 63.5rc
Since 1084 and W2 both have less than 1% mass of elements beside (Fe & C), therefore W2 1 extra rc came from Particle/Fe3C strengthening. Ultra high carbon low alloy steel could yield up to 72rc, which can easily attributed to strenghtening from high cv%.
Keep it simple, let ~2.5cv% = 1rc particle strenghtening. Thus matrix strength of
1084 - 67rc
W2 - 67rc
aebl - 64rc
3V - 62.5rc
Cleary there are MATRIX strength differences between low alloy and high alloy steels. When cutting activities interact with steel matrix and where strength is an advantage, qed stronger is better. e.g. push cutting where carbide/hard-particle are not completely shielded the edge, so matrix strength is important.
Continue looking at strength (not toughness)...
Why 3V is 1.5rc lower than aebl? Well
1. Most likely due to high % of RA. Mo is a phase stabilizer - in this case, increase the temperature of carbon precipitation and diffusion.
2. or inappropriate ht, didn't put enough carbon in solution.
Whichever way, 3V's matrix is the least strong among listed steels.
Wow, sound like we all should use low alloy high carbon steelsWell, unfortunately ht outcome of these steels ended up poorly - combination of large grain; weak grain boundaries; high % of plate martensite; large particles. 1084 or below reduces the magnitude of listed problems. Good thing: Aldo's 1084 with added elements grain refinement help minimize some of the listed problems.
Steels: D2, 3V, Infi, Vanadis4e, Elmax, s110v,... throw in wear resistant and corrosion resistant and elements to stabilize phases + pin grain at cost of matrix strength.
Toughness is strength working in conjunction with energy absorption+dispersion volume&speed&direction and much more...
^ this :thumbup:
WOW, 1095 and W2 at 67HRC?
People seems to use the the word strength in wrong meaning... everyone know there are 3 type of strength, shear, tensile and compressive.
Rockwell hardness is not directly translet into any type of strength... yes hardness does have a role but there are also other properties like yield elastic limit, elastic modulus, shear modulus... and many more... it just not that simple as your summarize.
Good example is diamond, extremely fine grain as material can dream yet one of the hardest material on earth, but we know it not very strong stuff...
In specific, can 3V have hrc similar to aebl? .
Yeah. In fact I doubt AEB-L hits 65
^ that's not even a high aus temp because the application calls for a lath martensite. And that's after a low temper too. It's a function of a high conversion %, avoiding all those messy structures that lead to poor edge stability. 3V will never have the fine edge stability potential of W2, nor will any other complex steel, but you can get pretty darn close. But not with the book HT.
One has to be careful comparing steels though because unless they were all optimized you might be comparing apples to oranges.
I started out using W2 and decided to switch to stainless shortly after. The decision was based largely on sharpening hunting knives for people and seeing them come in with blood, hair etc still visible on the blade the next fall. I thought to myself why make a perfectly good knife and sell it to someone who will not take care of it and then bad mouth me and my product when it rusts, when in fact it is their fault. It did not make sense to me.
Why Use Carbon Steel?
I've never found a good reason not to use carbon steel.![]()
