BluntCut MetalWorks
- Apr 28, 2012
Cypress & KuRUpTD - both of you are in. 2 more days to enter.
Chris - Good idea to use diamond to clean up the blade. However the blade is still not totally straight, so I use AlO (with mud) to abrade away the soft stainless lamination and not getting deep scratches. 60 grit AlO scratches leave very shallow scratches on cpm-m4 at 65rc, equivalent to DMT Fine. btw - #4 is quite straight & clean. #5 is about perfect at this point.
I'll sharpen #5 and test it, to check/guess amount of Retained Austenite. If RA is too high (i.e. performed poorly), I will apply sub-zero or Cryo soak + tempers (if I can get my hand on lN2 without spend big buck for a dewar).
edit: I will use/try 120 grit ceramic belt to clean up, just dunk in water often.
