Would 1/4" thick 10" blade be stronger of forged vs stock removal?
If I have an option I would choose forged it's stronger if done properly.
But machine forged would be needed to really get the benefits...at least that's what really reading the material seems to say.
So sure, if you had a choice of an industrial scale knife forging company's product, why not?
Don't see that around though.
Cool, my two cents, based on science, is that while quality steel appropriate for the job with optimal heat treatments, also appropriate for the job, are the primary considerations, the OP asked which was best, and I said forging, as long as the smith knows what he's doing in shaping anything more than a regular straight knife. Take away any kind of special or funky design and you're right, normal stock removal is probably the best, given the correct steel and production of the blade and price. How it can be argued given even just the presented evidence is honestly beyond me, but to each his own. You think it's useless for a quality steel, I know it would enhance a quality steel if done right.
The science you are quoting is wrong for this application. I just don't understand how you don't see that. I have repeatedly indicated that there is NO knifemaker that has a 25 ton+ forge. Those die forges instantly shape a block of 2200 degree steel into the desired shape with a hammer pressing at 240,000 psi. Not even an 800 lb gorilla wielding a 100 lb hammer can do that. The knife forging methods used apply very little pressure to a SOLID. The forging process helps in removing voids inclusions etc., not in making the steel mechanically superior to a high quality piece of billet made from rolled stock which is properly heat treated. The only steel that forging has an advantage over is a cast steel. 99% of all knife steel is rolled stock not cast. Poor heat treat is the biggest killer of knives. I like forged blades not because of mechanical advantages(which are non existent) but because the knifemaker poured his heart into making that knife. I find that very cool.
go to shop talk and ask the knife makers this question. Lets see what they say. Those are the ones in the know.
Well then, there should be a video of it, right? I'd love to see that. I mean if anything has been done in the last 7 years it should likely be on video.
There's no doubt their doing this on Army bases is much, much older than that...: From what I can remember, the servicemember who recalled this dated this to the early 80s: I doubt they needed to do anything during the Vietnam era, waiting list and all (though they do give much shorter wait times for active service members). I'm actually surprised they ever bothered doing this, since their reputation has been stelllar since the 60s, and the multi-year waiting list is about as old as that... I do hear Randalls are still to be seen, most often on officers... I think soldiers are more vulnerable to have their stuff stolen or banned...
Gaston
Gaston
I'd love to see that. I have two Randal #14's. Beauties.
What's funny is that the article is simply saying crap like edge packing is nonsense and that forging a blade to shape has a tangible effect on "complex" shapes where crack reduction is necessary, basically anything more than a straight blade with no curves or shapes can be better forged to shape. He says that basically everything about forging is just extra work, except for when grain flow is a consideration.
I guess you missed that part and want to say that forging has faded away from usefulness but the guy writing the article says he still prefers forging. I presented the same information as Cashen in his article, yet you're using his article to disprove something he didn't even try to disprove in his article, and as a matter of fact, he said it is undeniable. if you're going to have a "complex" blade shape, forging is good. If not, it's not worth the cost. I've said that multiple times and the article you posted basically says the same. Are you arguing against the article you yourself presented?
That's exactly what I said and in fact, used the same example, a crank shaft.
And I guess this section of one of my other posts means nothing?
In other words, the Department of Defense and military research and development groups say this is a real thing and should be accounted for.
Is funny, when defending the grain flow theory, it always shows that crankshaft picture! Problem is that big hunk is a casting, with all it's dendrites forged down to resemble a wood grain pattern. We forge steels that have been trough zillion times reduction at the mill from the original casting!!!
Forging is indeed economical since you have less steel wasting and less belts to spoil grinding afterward..... i have yet to see a "complex" blade shape ;)
There is no [and never has been any such thing as ] edge packing !!!! The flow photos show , for the most part , inclusions. Therefore the better the steel the less the flow pattern there will be..Forging doesn't close up voids [ that don't exist]. Only in very critical parts will things like anisotropy , inclusions, etc have a significant effect with forged parts. . BTW there is a difference in a PRESS forge and HAMMER forge and that shows up when forging large sections. Learn some metallurgy before making comments !!
The problems in things like kukris breaking may be from using old truck springs that may contain micro-cracks which sometimes suddenly get much bigger.
Finally, one of the forum authorities on steel. Mete, I am sure you have discussed this topic countless of times in the past. But can you answer op's question? in simple terms.
Answer to OP-- No ! If you forge or machine a kukri the lines of inclusions will be the same , stretched out in the direction of the blade.
The most common reasons we see blades fail dramatically almost always boils down to one or a combination of three issues:
A) Inherent flaws in the material, which no smith or grinder or heat-treater can entirely correct,
more commonly,
B) Bad heat-treat, which usually means the steel was over-heated and the grain "blew up", making the whole piece much weaker,
and most common of all,
C) Inappropriate design/geometry for the intended use, which usually means either blatant stress risers at points of leverage or someone trying to chop through a cinder block with a chef's knife (wrong tool for the job).
I'm reminded of a thread some years ago discussing horizontal vs. vertical scratch patterns in a knife blade, and whether/how much they affected the blade's overall strength. The folks who were most adamant that it made a huge difference cited a 50-year old text on how airplane wings were
constructed... well I'm sorry guys, but a knife blade isn't an airplane wing or turbine blade or a screw from a giant tanker ship. While all the same concepts obviously do apply, the pieces themselves are entirely different animals.
Far more than "grain flow", what's actually useful and important to remember is, the simple fact that grinding a complex shape like a crankshaft out of a huge block or a proper kukri (not just a kukri-shaped machete) out of a very wide bar wastes an awful lot of material. Even with a relatively simple knife shape, a bladesmith who can skillfully forge it very close to its finished shape wastes very little steel, whereas a stock-removal maker like me ends up literally throwing away roughly half of the bar he started with. That's just the nature of the beast... I'm removing stock. ;)
On a 4" long by 3/32" thick blade, that's not really a big deal. But when you start grinding 10" long bowie blades out of 1/4" or 5/16" stock, it results in a lot of money laying on the floor in the form of completely useless steel dust and belt grit.
In the pictured Condor kukri it was accepted that the breakage was the result of an inclusion and a faulty heat treatment. Those things can happen with forged knives as well.
Right... it's pretty clear that the grain in that broken knife is extremely coarse, and that's going to cause massive problems no matter how any given piece was forged, machined or even cast. That example is irrelevant to this conversation, because it's very obviously a heat-treat issue, not a shaping issue.
Ah, but you're not seeing that if the grain flow was optimal, it could be made several points harder, several ounces lighter, or with a steel that doesn't need to be quite as tough as 5160.
You're introducing completely different factors that really have very little to do with grain structure or "flow". Hardness, weight, and the inherent characteristics of whatever steel the maker started with are almost entirely irrelevant. You have to compare apples to apples to figure out how much difference there really is between one factor and another. Tasting whiskey is not very helpful when trying to decide which wine is better... ;)
Likewise, when discussing Nepalese kukris, it's important to keep in mind that those cats are very seldom using fresh, new steel... they're using old beat-up leaf-springs and whatnot, that have been subjected to who-knows-how-much stress and material fatigue long before the bladesmiths ever got their hands on them. So once again... there's no fair comparison to be seen (they're starting out with the deck stacked against them material-wise anyway, and we have few if any examples where the same piece of steel was used to make two knives, one forged and one ground).
I suspect you may be thinking of "grain structure" in steel, like the grain in a piece of wood. It just doesn't work that way, unless there's a boatload of inclusions (see "A) Inherent Flaws" at the beginning of this post), as mete explained.
So sure, if you had a choice of an industrial scale knife forging company's product, why not? Don't see that around though.
Actually, we do see that very often in the kitchen knife market. A high percentage of very well-known European and Japanese chef's knives with integral bolsters are forged to shape and then finish-ground, simply because - just like a crankshaft- that's the most cost-effective way to make them. Not because it makes an inherently stronger knife.
Sorry for the long-winded and mostly repetitive post... I'm not trying to lecture anyone, it's just that thinking these things through and typing it all out helps me keep it all clear in my own head. :)
Almost anyone can take a piece of whatever steel they can get ahold of and grind off enough steel to reveal the blade awaiting inside and then send it to Peters or Bos facilities for heat treatment, it takes a master smith to understand the science and underlying art in forging a piece of steel to enhance and showcase a piece of steel at its climactic capabilities.
There is no such thing as the "climactic capability" of a piece of steel. As JS Karl Andersen was quoted earlier, the steel is as good as it's ever going to get when it comes out of the mill, and the best any maker can do is not screw it up too much.
Quite frankly, I find your comment more than a little offensive. I think you'd be pleasantly surprised to find out how many makers who "just grind until it looks like a knife and send it off to someone else for HT" take all of this very seriously, and devote thousands of hours of unpaid study to everything involved in making an excellent knife. I invite you to talk to folks like Bob Dozier or Chris Reeve, and see how they feel about that statement. I never met him, but if the late great Bob Loveless was still with us, I have a pretty good idea what he'd have to say on that matter.
Claiming that only mastersmiths understand the science involved in making excellent knives is not only short-sighted and ignorant, it's just plain rude. :thumbdn:
"climax
[klahy-maks]
noun
1.
the highest or most intense point in the development or resolution of something; culmination" Simply saying the highest culmination of knifemaking generally involves forging or else they'd allow stock removal methods for the ABS master smith test.
I never said ALL knifemakers who practice stock removal are lousy. If you took it that way, well, nothing I said was intended that way. You have to admit, though, that anyone can get a belt grinder and some epoxy and other materials and make something close to what could be considered a knife whereas if you own a forge and the associated equipment necessary to forge something close to what could be considered a knife there's probably at least a little bit of knowledge. I'm not saying any kid who rides a bike can win the tour de france, but I am saying anyone in the tour de France can probably ride a bike. And I'm also not saying that if you're a great bike rider you HAVE to ride in the TdF, that'd be silly of I did say that because it's so obviously not the case.
If you don't like or want to use a forge, that's what you want and I wouldn't blame you, but now it seems like you're disparaging those who forge.
If you want to disagree with me and what I've said, that's cool, but don't go putting words into my mouth and making an argument where there wasn't before. Now instead of talking about the issue at hand we're discussing what will obviously lead to an argument and I don't want that.
In the end I don't really think there's been a lot of knife testing concerning the impact strength of a good forged knife vs a good knife that was ground down. It would take a ton of work and it would require that each knife made gets destroyed. That's the only reason there's anything close to decent tests about edge retention, it doesn't destroy the knife. It'd be nice to see definitive proof if a properly forged knife made by someone with tons of experience can withstand impact forces greater than one where the grain flow runs simply butt to tip, but I don't have the money to fund something like that. Maybe the ABS can find some knifemakers and bring about a competition. I'd watch it.
Again, if you felt slighted, it wasn't my intention. Maybe I worded it wrong or without enough of an explanation or maybe you're just too sensitive. Either way, there's no point in getting personal when no personal insult was conveyed.
...but now it seems like you're disparaging those who forge.
Nothing could be further from the truth! I happily encourage and promote nothing but the highest respect for skilled bladesmiths, and nothing I've ever posted anywhere should be construed any differently.
Well shoot... I intended to send this as a private message, but it seems your profile settings do not allow that. So it's going to have to be right out here in public...
You have to admit, though, that anyone can get a belt grinder and some epoxy and other materials and make something close to what could be considered a knife...
I do not "have to admit" any such thing. At the risk of sounding confrontational, it's not nearly as easy as it looks. And if you really think it is, I wholeheartedly invite you to give it a try at my expense (see below*).
Having ground a few hundred blades and having helped teach a few people to grind blades, I can assure you that a stock-removal knife doesn't just happen because someone got their hands on a belt-grinder and some materials. I can also assure you that starting a fire and banging some stuff against some other stuff (see how ridiculous that sounds? Just as ridiculous as saying that anyone with a grinder can make a knife) does not necessarily take any particular knowledge.
That does NOT mean I'm "against" makers who forge, in any way. Quite the contrary! The reintroduction, and furtherance of bladesmithing techniques over the last few decades has been a huge help to everyone who enjoys and appreciates excellent cutting tools. As has the continuing evolution of those who make knives by stock-removal. To ignore or dismiss either approach would be just plain dumb.
*If you have not made a knife via stock-removal before, please accept my invitation to visit my humble shop. I'll provide the steel, the equipment, and instruct you to the very best of my ability. I will include the knife you grind with my next batch, so it gets the best heat-treat possible. There will be zero cost to you except your time and travel. I say this as a personal challenge, but more importantly as a way to play my small part in continuing the long-standing tradition of knifemakers of all types, helping others learn firsthand what really needs to be done, to turn a chunk of metal into something that will truly perform as a cutting tool.
Now then, back on topic...
I would appreciate comments on whether a 10" blade of 1/4 carbon steel would be noticeably stronger if forged rather than made by stock removal?
The short answer is emphatically no.
I would honestly love the opportunity to learn from someone who has a reputation for making very good knives. If you live near virginia then I would love to come by if you're serious. I by no means said it was easy to make a good or great knife via stock removal, I just said that anyone with a grinder and the basic supplies can make something with some kind of semblance to a knife, which is undoubtedly what my attempt would be classified as.
"climax
[klahy-maks]
noun
1.
the highest or most intense point in the development or resolution of something; culmination" Simply saying the highest culmination of knifemaking generally involves forging or else they'd allow stock removal methods for the ABS master smith test. -- And this has nothing to do with how a blade performs. Plenty of stock removal blades could easily pass that test
You are correct, there isn't many comparisons. However, There are plenty of demonstrations on both sides of how well a properly heat treated stock removal blade and a properly heat treated forged blade perform and as long as the HT is excellent, you will not likely notice any difference.
One ABS test is the bend test. Here is a great forged blade doing it:
[video=youtube;4v5RAJsLTVU]https://www.youtube.com/watch?v=4v5RAJsLTVU[/video]
Here is a great 1/4 inch thick, stock removal blade killing that test. Proper HT and steel is king:
