- Dec 3, 2015
Looks like it could be used as a pipe knife.
Absolutely! Along with the spatula, the end is flat and squared. Perfect for tamping.
Yeah I love toothpicks.I think because even among other trad knives they look okd school.![]()
I also acquired a Zorro Barlow made by the Novelty Knife Co.
- GT
I glued the pieces first, only putting glue where the stitches will go. This isn't really necessary to the finished product but it holds everything together while you work and makes it 10x easier. Then I punched the holes with a trident-shaped punch, again a shortcut that saved me tons of time and frustration instead of trying to use an awl for every single hole. Then, I used a "saddle stitch". Get a piece of thread 6-7 times as long as the run of stitches and put a needle on each end. You'll be sending both needles through the same holes in opposite directions. Start by going through the 3rd hole, even out the thread on each side then start stitching towards the short end. Then, go back over it so the short little bit on the end gets double stitched and continue on down the line. One you reach the other end, go backwards again, double stitching just like you did when you started. Go back 3 on one and 4 on the other so the ends are on the same side, then tie it off. I used a normal double knot and a drop of glue.
Also, make it a bit tighter than you think you should. The leather will stretch and hold your knife nice and snug. Mine will hold the knife in place upside down and even with light shaking. A moderate shake will make it slide out a little at a time and a heavy shake will of course shoot it out. I feel like this is the perfect amount of tension. Make sure to leave enough room to get your fingers in there and grab the knife. Leave a little bit of knife sticking out and/or don't stitch it quite all the way to the top.
For mine, the amount of knife sticking out plus the un-stitched portion at the top adds up to almost exactly one inch. I'd call that the bare minimum to comfortably grab the knife and pull it out. On my next one I'll give myself an extra half inch or so of finger room. For reference on the tightness, my knife is 1.2 inches from the backspring to the spine of the blade while closed at it's widest point and the holster is 2.35" between the rows of stitches. That leaves you making your pouch just a hair under twice as wide as the knife to go in it, (x1.96 to be exact). Also keep in mind that the thickness of the knife will affect this too. My knife is almost exactly the same thickness as my standard trapper (also made from a RR kit).
Got in the Remington UMC R4, just needed some oiling to get it's snap back. From another thread, Camillus made. It will be my SAK farmer alternative.
My latest and greatest addition was a gift from Ken (a.k.a. Itsasportsbar) for which he went above and beyond in sending to me after I expressed appreciation so long ago over his example.
